First chop 2nd build
bruders8146
Where to start?
My name Lewis I'm from Kent England.
Back in June I stumbled across a 1980 cb650 custom a few streets away from my house. I had always wanted to customise a bike into something like a scrambler,brat,cafe racer type so bought it for £1500. (This was a massive impulse purchase and no research) clearly this would bite me in the backside later on.
So I got it tested and rode it for a few weeks hated the bars and swapped them for an old set I had laying around (came off a Yamaha xt350) and instantly the bike felt so much better to ride.
I made a rear mud guard from fibreglass and stuck some replacement indicators and tail lamp.
First time I made a complete item from fibre glass and I was mega happy with the result.
If I was to do again I would of made a clip underneath to secure wiring better.
After about a week I got the bug and was desperate to strip and have a tinker.
So stripped bike completely.
But first I bought a cb750kz tank as I knew the original tank would not work for the vision I had.
Then stripped and cut frame up. Looking back and with inexperience i should have made a jig first but my theory was I wasn't amending any main angles or major structure it was just a seat platform
When I cut the frame I kept an old section of the original frame that I went in to use on my new seat section. The reason I did this was
1st I kept the original mounting points
2nd it already fitted the down tube so why make one.
I just bought tubing that was slightly smaller that I used as lugs. Slipped new frame section on and blasted with the welder.
Oh sorry for the background picture.
Then had a friend paint the tank for me
I decided I wanted to run the popular gsxr front end so bought some used 2007 front forks and stripped them and replaced oil,seals and sent tubes away for 're annodising.
I purchased used calipers and also stripped cleaned and fitted new seals.
My home made fork compression tool
I bought a new stem and top yoke from a US company and pressed stem into a original gsxr lower yoke.
Then temp fit into the bike
I have purchased from the US front and rear hubs 40hole to run spokes wheels,the rear is a disc conversion.
Sent these away yesterday to have built up for me.
Fronts 3.50 x17 running tyre 120/70/17
Rear 4.25x17 running tyre 160/70/17
Currently the top yoke doesn't fit (manufacture issue) the holes are 48mm and my fork are 50mm got into the phone and the chap in the US was mega helpful and sorted it. (It so true about American customer service being good).
So I bought a few other items which I'm currently awaiting.
New front brake lines
New lower yoke to match the top
Offsett spacers for rear wheel as I have bought a disc brake conversion and I was going to run fatter tyres 16/70/17
Front offsett sprocket
And new clip on woodcraft bars
So this is how the bike currently stands and is just a mock up.
All constructive criticism good or bad welcome
Any further advice definitely welcome.
As I did just jump into this and I see why people choose not to modify these so much.
Sent from my SM-G955F using Tapatalk
Been busy.
However the new shocks I have bought see not long enough. So looking to buy 360mm instead of the current 335mm
Lovin this excellent job with 2nd build!!! Frame is great but those wheels look stellar! Wish the was more. How hard was it to get the engine out?
Sorry pal for late reply.
Seemed people wasn't interested so I kind of switched off.
Engine is mega heavy but lucky for me the 650 has a removable section.
And I used a trolley jack to support the engine.
I then made a engine stand.
So not much has really happened lately.
Many purchases of titanium bolts and other tools etc.
I have painted the engine and currently in process of polishing engine covers.
Painted frame at work the other night so just waiting for it to harden so I can polish and start reassembly
Oh and just bought a ultrasonic cleaner for to fully strip carbs for a good clean.
Can anyone assist in info on upgrading pilot jets etc as I'm going to be running stacks I'm told I would need to up jet 2 and maybe get a new needle?
Can anyone point me in the direction where I can buy these.
Many thanks
Looks lovely mate.. not a fan of the Met Green and gloss black but that's just my opinion.. really quality build !
I finally had my project running at the weekend.. still loads to do!
What paint did you use on the engine..? I've had issues getting decent paint.
Nice work. So...adding 25-30cm of longer shock might make the difference but otherwise man that rear tire is going to hit the subframe.
It was just some rattle can stuff I found on Amazon. Hycott gloss black engine paint.
Yeah I totally agree. (Also makes it difficult to mount a number plate) which I have no idea what to do with this.
I'm not 100% happy with the rear shocks and want some replacements.
Any ideas.
Eyelets for top and clevis for bottom. Currently 340mm
I have gone a little OTT (over the top) with the nut and bolt situation.
I had a company manufacture me a new swing arm bolt and a rear wheel axle from titanium
I also asked him to replace the other engine mount bolts etc etc.
So other than the engine bolts I have all titanium nuts and bolts for this project.
Ordered a rear set bracket from cognitio and had to put my Mark on it with chopping a few bits to allow it to work on the 650 frame (as it has a removable section
Any ideas.
Hagon makes any size,type shocks you need. A kick up in the rear of the hoop is how most folks avoid the tire rub.
