First Motorcycle build- 85 CB650SC
roda
Hey guys, So this is the first bike I've ever tried to restore. Im quite familiar with getting my hands dirty on cars, so I'm not a complete noob. So I snagged an 85 CB650 Nighthawk for a few bones. It doesnt run as of yet but the motor is free. It's been sitting for the past 4 years. Ive already pulled apart the carbs and done most of the cleaning, but Im having a lot of trouble with the choke plungers. 3 of them are completely frozen in the carb. They are currently sitting with PB blaster soaking in for the rest of the night, but has anyone encountered this before? whats a good way to break them loose? I've been pulling on them so hard that I'm worried I might bend or snap them. Ill get some good pictures up once I get a chance
So here is an update guys. I cleaned the carbs and attempted to clean the tank, but it was just rusted to hell, so I figured I would buy a different one since i didnt like how the stock one looked anyway. I found a fairly cheap '72 cb500 tank, which was already sealed and just needed a good paint job. I also replaced the spark plugs and checked for compression. Shes good there. So I've got spark, I've got compression and I've got air/fuel mixture. I tried to start the bike today, but it would only kick a couple times. It sounds like it wants to start but just wont. Maybe I need to tune the carbs? I also noticed the needles on the ends of the pilot screws are broken on a couple of the carbs. could this be the problem (I screwed them in to stock specs when I reinstalled them)? Either way I'm going to keep tinkering, but any advice would be greatly appreciated.
Ive also got some parts on the way. A nice circular headlight to replace the ugly rectangular one, and some lower profile turn signals and a smaller tail light.
Here are some pictures of stock up to now. The tank will be repainted soon, black and white is just how I bought it. I dont know if anybody on here works on cars as well but thats my other project in the background of the last picture.
Whats the fuel look like if you drain the bowls? I was good on spark and compression, and thought my carbs were clean, but after a good soaking of carb cleaner I started to get some debris flowing out of the bowls. Wouldn't start until it flowed totally clean. Just a thought. Nice find on the tank. I hate the stock one. I'm looking for something new for mine as well. Specs on the evo? I was a 240 junkie before the bike. Haha
Get the carbs clean and make sure you sync them. Check out the charging system also as they are famous for failure.
dont spend to much time on the carbs with the broken air mixture screws
if you cant get the stubs out of the body the carbs are scrap so see if the hole is clear first
stubs came out like cake. New mixture screws are on the way. The carbs are crystal clean besides that. So hopefully once the parts come in she will finally start up.
Lastly, its actually not an evo. Its a base lancer with an Evo turbo in it. Shes pretty damn quick for front wheel drive. With the clutch slipping, Im getting around 225 WHP and 210 ft-lb. Itll beat out any ralliart from a roll, but launching is pretty awful, I can spin the wheels till about 40 MPH
So after going through the carbs, and everything I could think of I still cant get it started. Not even with starter fluid. I took a look at the spark, and its seems a little weak. Its still blue in color but is fairly thin compared to the width of the electrode. So Im thinking its maybe an issue with the coils, but Im not entirely sure. Any advice would be great.
Might be a little late since you already ordered new ones, but did you check the voltage in/out of the coils first? Might you have plug wires swapped?
Also, if you have the means I'd check compression just to be safe. Would suck to throw parts at it when your piston rigs are shot.
