First post - cb360 won't kickstart
oathamm
Active Member
Hi guys
Here goes... My first of what I'm guessing will be many posts.
I acquired a '76 Honda CB360 last year at which point it fired up. Since then it's been sat in the garage gathering more dust. I've decided to get started on my build but I want to get the bike running first. I'm a bit of a novice so go easy!
I put new plugs in.
I took out the battery and put it on charge however the indicator suggested the battery was bad.
However I put the battery in the bike, turned on fuel choke ignition etc... And attempted to kick start - the electric start is missing a button.
When turning on the ignition the headlight came on which I guess means the battery has something in it? However no other components worked I.e horns signals etc...
Numerous attempts at kicking yielded nothing.
I removed plugs and inspected them for a spark when kicking over and didn't get any spark.
So a few questions:
Should I just buy a battery and retry?
How come the headlight came on if the battery is dud?
How come no other components worked even though headlight was on? Are these on a circuit via alternator?
Do I need a working battery to kick start?
Should I have seen a spark when kicking over with plug removed?
Any tips on how to go about troubleshooting?
Once I get the bike running in its current state I will know what I am dealing with and will continue the build accordingly.
Thanks for listening.
Matt
Headlight will come on with minimal battery, but bike needs fully charged battery to actually start (either electric or kick). Buy a new battery and retry. If there's still issues at that point we can return to them.
Try turning off the headlight and try kicking it over. If there's not an "off" for the headlight just disconnect it. The headlight is probably stealing the power for the ignition coils when you kick it over.
Check the voltage on the battery. Less than 12V standing, nothing on, the battery is dead. The bike will not run with a dead battery. You will buid up strong muscles on the kick start leg though.
Thanks for the replies guys, I got a new battery and it fired up :-)
Sounds rough as hell though, lots of popping... Does that mean there is a timing issue?
I took a reading of the battery both cold and running, cold was approx 12.4 reving to around 3k showed approx 12.52 I'm not sure if that's good or bad? I am guessing that the timing issue could result in the alternator not putting out as much power as it could?
I removed the timing cover to try to check the points, the screws look pretty mangled is it possible to buy new points and fixings?
My next step will be to try and time it and if possible get new points then check the compression in the cylinders... Or should I do compression test first and get new rings if required before working on timing?
Thanks again
Matt
I'd do a basic service of all the regular maintenance type things first. That way you have everything setup to stock and will know better where you stand. If you have a manual, there is usually a chapter that goes through all the regular maintenance items like: timing, valve clearances, cam chain tension adjustment, etc.
Now that you know it runs you can go one of two directions. You can either tear it down and do a complete rebuild or get it running well. Since you seem to be pretty new to these old bikes, I'd do the latter. it's getting warm out and I'm sure you'd rather be riding than wrenching and watching others ride by.
Start with what HerrDeacon advised, going through regular maintenance (timing, valves, etc.). Check the screws on your points to see if its just the heads that are damaged. If the threads are actually bad (which I doubt) the points could move and timing would never be right. Replacement points are widely available, and they often come in a relatively cheap "tune-up" package with the condenser as well. I don't think they come with screws, though, so you'll have to go to your local hardware store or order them from Fastenal or someplace like that. The parts fiches available online at sites like BikeBandit or CMSNL should give you the exact size of every fastener, which is really handy. It'd also be a good idea to pull and clean the carbs really well. Most running problems in my experience are timing and/or carb related so spending some QT on those systems should pay off.
