First Time CB400/4 build
tonym547
Hey everyone picked up a 76 CB400/4 and making it my first cafe racer project. I'm in the San Diego area and am really looking forward to this. I've done some mechanical work with my dad on cars but am fairly new to bikes. Owned a '05 R6 a few years ago which i loved but had to sell it. Been wanting to build my own cafe for years but never had the time due to the military. Now I'm out and I have the time and money to do this. Looking through this site i see there;s a lot of knowledge and experience which is great cause I know I'll be asking a lot of questions.
Here's some pics I started last weekend and would of continued this weekend but went snowboarding with a buddy and he ended up breaking his neck. He's all good had to have some surgery but I just got back down to SD so no work got done this weekend. But will be hot on it when this coming one comes around. Look forward to some good advice.....
Also these are my plans:
* New front end mostly for the brakes ( saw someone using a 02-06 R6 front end?)
* Rebuild and overbore the engine (saw a 466 kit but was hoping to see what it takes to make it a 496)
* Looking to get a seat made from kott motorcycles
* Keeping the rims getting them powdercoated
* See if i can get some koni rear shocks
Tell me what you think
I thought so, they are great dogs. I grew up with Shorthairs, and have a 2 yr old Wirehair now who likes to eat Bondo. Talk about a mess trying to get it out of her beard before it dried! Anyways good luck on the bike project i will be following to see what you come up with.
Cheers, Mike
Hey that's a nice find there... the 400f's are pretty scarce. My brother has me on the lookout for one but I haven't seen one come up for sale locally since I got mine three or four years ago.
Welcome.
She's got a little oil leak, huh. Ha ha. That'll be a good project bike man! Good luck!
Welcome to DTT. The 400f is a GREAT bike. You look like you have a lot of work ahead of ya man. Be careful with the big bore setup, as once you go so far, you lose some of the streetability. Pure race bikes arent much fun on the street.
As far as the USD forks, it can be done, but isnt really an upgrade. Those forks werent designed for this bike. You may be better off looking for something from the same era with better brakes and rebuilding using gold emulators and progressive springs. You could probobly use a GL1000 setup (dual disk, spoked wheel) pretty easily.
Where would I find how to do this...and how hard is it to accomplish?
Having built four of these bikes I can offer the following:
Buy a factory service and parts manual and consider a Haynes manual too. Invest in proper metric tools.
Leave the motor stock. If you want a bigger motor, buy a bigger bike like a CB550F or CB750K.
The single front disc brake on this lightweight bike is good enough after properly rebuilding brake cylinder, new stainless steel lines, new caliper and seal. New brake lines make all the difference in the world. I prefer a drum brake up front. If you insist on a dual disc front end you will need a 550 or 750 front end, twin discs, larger reservoir with lines for two calipers etc. Search for threads on this forum and SOHC.com
Inspect and adjust your cam chain and adjusters carefully for they wear out on this motor, will make noise and will cause problems down the line. Test for even compression on all cylinders and if there is not, determine why it is uneven. Do a leakdown test. Refer to the manuals and replace anything the is out of factory specifications (valve springs, guides etc) New seal kits and/or new gasket kits will insure a leakproof motor. New carb kits save leaks and headaches and increase you main jet if you remove the stock airbox configuration. Filter your fuel lines and change your oil and filter regularly. Your starter button is useless or will be useless soon. New OEM starter controls are $100 from Honda, or simply remove the starter, blank off the hole and shed a few pounds off your bike. Replace the billboard sized rear brake light with a smaller and good looking brake light.
A few links of interest:
http://www.cb400f.btinternet.co.uk/
http://www.400fourstore.com/
http://home.comcast.net/~eyhonda/home.htm
Great bike, good luck and post your progress! Here are a couple of mine:
All good advise here from swan and VonYinzer, I agree with them 100% on overbore and everything else said! There are a few ponies to be freed in the little 400f's with relatively simple changes that they did not mention. Swan touched on losing the stock air box and that is a must in order to bump up HP. Going with a set of K&N pods will help the engine breath much better than the stock set-up and still offer you great filtration and reliability. The stock air box on the mini-fours were way too small and restrictive, so by swapping to pods and properly jetting the carbs, you will notice a difference with just that mod. If your making the engine breath better, then I would suggest a different exhaust too! While the stock 400f exhaust is a work of art as far as stockers go, its collector was rather poorly designed for proper air flow and has a constriction in the middle of the flange. I suggest a nice MAC four into one or a nice vintage Yoshi. Also if you change the exhaust and add pod filters, you will want to do the jet work after both, as both will effect jetting. To gain some more and make the throttle response much better, go with a dyna "S" electronic ignition system and dyna 5 ohm coils. While doing that mod it is best to get some good quality plug wires and some nice shiny new plugs. I also recommend dropping one tooth on the front sprocket, as the 400f is a six speed this mod will boost your off the line and low end torque without sacrificing too much top end speed, it is well worth the trade off! As for your front end, the best thing you can do is keep the stock and add a few goodies to make it the best it can be. Racetech spring with goldstar emulators, new fork oil, and a solid fork brace will make the forks perform better than the bike can, so no need to go with anymore performance technology there! Swap to an oring 530X120 (cut down to size) chain with a new rear sprocket (same size as stock) and your drive train should be up to par. There are several options as far as rear shocks, but new ones will outperform your old ones any day! Hope all that helps!
The 400f is a great little bike, find the member here Kanticoy's thread on his 400f if you want to see someone going "all out" on a 400f build, but he is basically building a full on race bike!
Thanks for the advise I really appreciate it. Looking at your pics and then checking out Kanticoy's build I know have an abundance of ideas racing through my head. I appreciate it and can't wait to start back on it. Have the next four days off so i'm gonna be busy. Again thanks
The4re are as many ways to go as there are people on this forum. A clean stock bike is a sweet ride for sure, but it's your bike. Bigger bore pistons are available from a couple of sources and help to add a little something, but to get teh best out of that change, you start to chase bigger carbs, hot cam, new valves, porting job etc. Cubic dollars.
Break the project into sections or systems. For example. Strip and clean the motor and inspect the bores and head. List teh work that needs to be done to get it running, get it running well and to make it faster. If the cost of getting it moving under its own steam is high because it's all worn out, then MAYBE a set of bigger pistons might not be too much of an incremental cost.
If the motor is cherry inside (unlikely I know) then the incremental cost of changes is much higher.
Same for the suspension. Add R6 forks - good idea but what 's the cost and what wheel and disk rotors and calipers go with that. And what to do at the back end to keep it all balanced front to rear.
I use an EXCEL spreadsheet and list the items by system and I pretty soon get an idea of what I thought I wanted to do and what I'm now planning to do.
So quick update finished stripping it down to it's frame, and got the engine out.....(man that was a pain)...Drove up to LA to Kott Motorcycles. He does all vintage CB's and does makes real sweet bikes. Check out his site http://www.kottmotorcycles.com/Kott_Motorcycles/Home.html. Anyways talked to him and got a lot of great ideas just bouncing stuff back and forth. He's fabricating my seat, making my rear sets and powder coating the frame and wheels for me. Also fixing my tank (had a rough life). Gonna start tearing into the engine tomorrow.
Take lots of photos for your own reference during the motor teardown.
I definitely am. Looking to buy all my engine mod parts from the 400 four store. Anyone know what K&N filter pods I need for Keihin 26mm CR carbs.
