First Triumph. Pre Unit Build
lemc
Real hyped on getting my first Triumph today! never had the chance to tinker much with british bikes so im looking forward to learn and be enlightened along the way..
My first question is identifying it, anyone know much about the vin numbers/engines on these things?
The bike looked like it had already been someone's project once, the previous owner had it almost since new, but somewhere along the way the tank, handlebars, seat etc had been changed, Im keen to make it more into a more lighter looking bobber. (solo seat, low profile wassell tank, slimmer back tire, etc.)
The engine has good compression, and there is spark in the plugs, however the tank has some chronic rusting internally same with the oil tank, I'll treat it first then give it all a renewal, before i attempt to fire it up, I was also wondering what the best oil would be to use? Should probably get a manual to start with ha
cheers guys, cant wait to get started.
Tear the engine down and split the cases before you run the engine any more than just testing it. There is a 'sludge trap' in the connecting rod big end journal in the crank. It fulls up with sludge, and block oil flow. If you don't clean it out, you WILL blow up the engine.
http://classicmotorcycles.about.com/b/2012/11/16/triumph-sludge-traps.htm
Changing that bike very much would be a bad idea. That looks almost like a survivor grade period piece. 80/90 or 90/90 front tire, 120 or 130 rear tire, add some cocktail shaker or similar mufflers once you extend the pipes.
Sprung solo is also period, but make sure you buy a really good one. The $30-50 thinly covered ones are worse than bicycle seats.
Where are you located? Pre-unit Triumphs require some tinkering that most modern bike mechanics have never dealt with (or usually even heard of).
Cutting your Brit bike teeth on a pre-unit rigid... that's going to take a set that clanks. Just finding the right tools is a time consuming and damned expensive process. And you ARE going to need a full set of quality Whitworth tools, those bikes love to loosen fasteners.
On the left side of the motor just below the barrel should be the engine number. It should read something like 6T xxxxx .
Look for the frame number on the steering head.
It's a 50-53 sprung hub and has the original frame and rear hub which makes it a great candidate to restore to stock. That is the original frame as far as I can see and doesn't look to have been molested much.
Unfortunately the top end of the motor is a later unit 650 top end and has 9 stud alloy head and probably matching barrels. They don't go around corners very well and that front brake looks like the stock steel device that contains very little actual braking ability.
It could look like this again and be worth a nice amount
Or something like this
Parts and tools are all available as are the few special tools to pull crank and timing wheel gears. Clean the magneto points and check for spark if the motor turns over. If there's no spark, remove the kill switch wire from teh end cover of teh magneto and try again and if still no spark, remove the end cap and see what's going on in there. K2F magneto will lose magnetism over time but can be rebuilt or fitted with a modern electronic ignition in that old mag body. Keep teh mag if possible. No battery needed for that ignition. :-)
Who's repopping Whitworth tools? I haven't messed with Brit bikes since 99, gave away my last 2 Triumphs (seriously, literally told a friend to come get them or I was scrapping them, pair of 64 T120C Bonnies). Had a Rickman project from 2006-2011, gave it away too.
BSF wrenches are the same across the jaws but they measure a different way. Usually they are stamped something like 1/2BSF 3/4W one relates to the head size and the other to thread size. Like a 6mm metric uses a 10mm wrench and an 8mm thread may have, 13, 14 or maybe 15mm heads.
Cheers for all your replies, Ill start looking into a good quality Whitworth tool set. Thanks for the heads up on the sludge traps, what would be the easiest way to locate them?
These were the numbers i found on the engine / frame,
F (or T) 1 910 +
T411 714
There was also a faded number on the staring head which was 39833
Anyone know anything about these?
The T # is a casting number. 39833 sounds right for a 53 frame, but why would anyone fit an older rear subframe and wheel to a later model frame? To make it look like a rigid and still have some rear wheel movement I guess. I'm sure the front loops were the same and that the swingarm rear end just bolted on the same way, but it's been a while since I used to play with "Trumpets"
That engine number is bogus. It's in the right place but should be stamped into the rough casting. Someone has filed down the original number and come up with that bogus one.
It's also not a set of replacement cases. They were also rough cast where the number would be stamped. I suspect it may be a slightly later T110. I think that the 6T went to an alternator by then.
