Float Overflow Leaking BAD. Sinking Floats?
Red Fthr
"Man is born free, and he is everywhere in chains"
BIKE:
73, Honda CB500 Four K2
PROBLEM:
Number two carb pours out gas via the overflow. It will hold gas but then will just start pouring out gas from the overflow. It actual leaked gas after I turned off the petcock at one point.
THEORY:
I rebuilt the carbs (new needles, jets, screws, etc.) bench synced and now I'm actually syncing them with a vacuum sync o meter. During the syncing process I kept getting readings that didn't make sense, a hanging idle, and then, after bliping the throttle a drop to a dead idle. I went through timing, gaping, and most of anything I could think of. I then noticed number two was not leaking but pouring out gasoline. I think it's from a "sinking" float/ non functioning float. Oh, and yes, the float heights are set to manual specifications.
QUESTIONS:
Could this be from a "sinking" float allowing an excess of gas to enter the bowl?
Does the leaking/ excess gas explain my syncing issues?
Any other reasons it would leak?
Are there any test I can do to be certain before I go buying new floats?
Just read about the sink or swim test which consist of filling a bowl up with gas and putting the float in it to see if it still has buoyancy. I got one new float already but the others were sitting in bowls with gas liner and gunk all in them, maybe they got damaged because of that?
1. Yes.
2. Not sure.
3. Yes.
4. Double check your float height and make sure that the bowl gasket isn't interfering with the float's motion.
You can also test the float.
I second the sinking float diagnosis. Mine were doing the exact same thing and it was because of a punctured/ damaged float.
Took the carbs off.
The gasket wasn't infringing on the floats.
By the video you can see my float seems to have good buoyancy still.
The gas doesn't look rust brown but is a littl amber. Should it be way clearer than that?
Also the new jets are 40s and the old ones are 38s. All new stuff is slightly bigger.
That doesn't explain leaking issue I don't think but just an FYI for any thoughts on my idle issue.
http://m.youtube.com/watch?v=vZsIYkPqHGQ&feature=plcp
Should I put the old stuff in to see if that makes a world of difference?
Put the float up by your ear and shake it. If there's fluid in it, you will hear it sloshing around, much as you would with anything that is hollow with fluid inside :)
River City Rocker said:
Double checked float heights and they're 22mm like the manual says. Number two, the green one, is giving me the issues. Could the left over gas fungus be causing any problems? I think I'll put in the original jets and see if that makes a difference. Maybe something isn't seating well?
http://m.youtube.com/watch?feature=plcp&v=KZryya1-dqE
If you have gas coming out of the overflow, it's because (a) your float height is wrong, (b) your floats are taking on gas or (c), your float needle isn't sealing.
That's what causes problems in carburetors. You would be well served to tear your carbs down and clean them thoroughly. Before they go on the bike they should be absolutely spotless.
Float heights are bouncy and at 22mm like the manual says. The carb that is giving me the issues has is painted green from all the gunk that was in the carbs. Could that be an issue? Oh and I shook it around after submerging it and heard no sloshing. Kinda coming to my wits end. Thanks for the comments so far.
http://m.youtube.com/watch?feature=plcp&v=IEV_Fkd4lDg
@Rich Ard the bodies and Bowles were completely stripped and thoroughly cleaned. The floats how ever weren't. I was hoping to get away with it because 4 new floats add up. I did notice a little line of green back on the bowl, so if these floats are just gonna dirty things up again then I'm gonna bite the bullet. If you're saying new floats is a must then that's what I'll do and go from there. Also I've been a little skeptical about the float needles since I put them. Ill give those a looksy.
Ok my camera sucks obviously but that little piece of black hanging there is part of the o-ring. I squeezed them in their little holes because I thought the o-rig wasn't suppose to show. Is that wrong? Is it suppose to just rest on top of the whole?
Just answered my own question I think. After looking at all 4, 3 and 4 weren't leaking and also had float needles sitting, what I would assume, perfectly. 1 and 2 float needles were recessed in the hole more and had damaged o-rings (due to trying to secure them better in their holes like the inexperienced ameture mechanic I am) and 1 had a slight drip which would explain that too. I'm gonna order new floats and put new o-rings on my needles. This time ill use more finess and let the screw secure them in place.
I think that'll solve my leaking issues. I hope that in turn will solve my idle issues and syncing issues. If not. Ill be back.
If your floats aren't damaged (taking on gas, not moving on the pivot) no need to replace them. O-rings, needles and seats need to be perfect, tho.
@Rich Ard I am all the wiser to that now. Thank you for your time.
