Up for sale is a stripped down and cafe'd 1980 Honda GL1100.
This is the product of a 1+ year build. The bike was completely disasembled and rebuilt (except the internal components of the engine). Just moved to San Jose, and have no room for the bike. Dont want to leave it at my folks house anymore.
The good:
-Progressive front springs (No air suspenson)
-LED turn signals
-LED brake and running light
-New headlamp
-Clubman bars
-Randakk upgraded front master cylinder
-New thermostat
-New Timing Belts
- New Front tire
-Brake system flushed with DOT4
-New Stator
-New Clutch Spings
-New battery and starter Soleniod
-Cafe Racer tail
-Customized Shelter with 1 piece door
-Hagon 2810 rear double adjustable shocks
-Custom painted frame
-Custom 70's era paint job
-new Steering head bearings
-modern fuse panel
-modded side covers
-New wheel bearings
-Fully rebuilt carbs
-Gas Tank is CLEAN! No rust issues
-New grips
-CB350 style mirrors
The Bad
- needs to be checked out by a Mechanic for final torque check and driveability check of all components.
-Needs new water pump. We have one in hand, with the gasket kit. bike runs fine and current water pump works. Just leaks oil from the water pump weep hole at the bottom of the case (Common issue with 1100's and 1200's). Will include instructions on how to do the job (can be done with motor in, with the right tools).
- All gauges work, neutral light doesn't.
Here is the link to the entire build. The Body and paint work (extensive as you can see from the build) is worth 2500 to 3000 alone.
http://ngwclub.com/forum/viewtopic.php?f=16&t=41885
And here is some pages about the build that I posted on this site:
http://www.dotheton.com/forum/index.php?topic=46505.0
And here is the Craigslist ad for people:
http://sfbay.craigslist.org/eby/mcy/5505658309.html
Very clean bike. Just needs a few minor touches to make her your own. Come by and take a look. Weekends are best, but can show the bike during the week too.
Call, text or email if you have questions.
510-364-6952 Located in the SF bay Area
Thanks for looking!
-Matt
The good:
-LED turn signals
-New headlamp
-Clubman bars
-New thermostat
-New Timing Belts
- New Front tire
-New Stator
-New Clutch Spings
-Cafe Racer tail
-modern fuse panel
-modded side covers
-New wheel bearings
-New grips
The Bad
Thanks for looking!
-Matt
