Fork Gator Issues /// PLEASE HELP
indianajonze
Active Member
SO. Today I attempted to remove the red dust covers from my 72' CB350 and replace them with gators (gaiters?). Took the wheel and fender off, took the headlight and blinkers off, loosened the small clamp at the top of the forks and then the big bolt at the top of each fork. The fork ears and lower dust cover came off easy enough but I'm pretty lost as to how these gators go on. The metal dust cover that the bike came with has a notch cut out of it allowing it to fit around an 8mm hex bolt. The gator doesn't have this.
Am I missing something or approaching this wrong?
Tops are probably too big for a good fit on tube.
Honda use a flange on base of headlight ears to hold gaiter in place.
You'll ave to make something to increase tube diameter to size of gaiter top
I think there may be a plastic plumbing fitting that works with minimal modification?
I know I've used PVC pipe as a seal driver and its a good sliding fit on 33mm tubes
Are you trying to put the new gaitors over the bottom triple clamp? Most gaitors I've seen just clamp to the fork tube.
Just making sure I follow this. So use PVC to bridge the gap between the bottom of the fork ears and the top of the gator? The PVC would be covering the part of the fork where it's attached to the bottom triple tree and would therefor have to have a spot cut out.
Do I follow or are we confusing each other here?
This is kind of what I'm trying to figure out. Should the bottom of the fork ear cover the bottom triple clamp or the top of the gaitor? On my bikes stock setup the top of the metal dust cover covered it but maybe I'll need to buy different fork ears to accommodate the gaitors?
Nope, the gaiter only fits as far as bottom yoke.
The tube is smaller than the hole.
Either 'trim' bottom of fork ears so it doesn't overlap or get new headlight mounting.
I usually grind all the flash/casting marks off bottom yoke
http://www.dotheton.com/forum/index.php?topic=11736.125
Pics at bottom of page
The bottom of gaiter stretches over top of fork slider to hold it in place
I know I took pictures of Brendon's bike,
Found pic of lower section, just need to find top
Okay this is helping. So, I should pull the gator down over the larger part of the fork so that its snug correct?
Also, here is a photo of the gators I'm using. To my understanding they sit this way as well (with the large end down). Hopefully that is correct?
They look like genuine Honda?
The top is designed to fit onto an extension of fork shroud/headlight 'ears'.
You need something resembling a thick washer, inside to fit fork tube, outside to fit inside of gaiter.
As I said earlier, there is a plastic plumbing fitting or pipe that works, just put a hacksaw cut along length so you can use a hose clamp to hold everything in place at top of fork
