Fork leak while on Kickstand
silverheli2000
Active Member
Hi All,
I've dug a bit on here but really am just needing a hopeful straight forward answer. I've had my bike for about a year now (72 CB175), and since I got it it only had the centerstand. The kickstand and kickstand mount were completely removed from the bike. I recently did some minor work to the front end which resulted in taking all fork covers off, cleaning up the forks, new headlight mount/headlight, and small cafe bars. That being said, it wasnt super easy to pull it up on the centerstand with the small bars, so I dug on feebay, found someone selling the proper kickstand mount/kickstand to this...got it in, cleaned it up and installed it. Ah hah...it now has a kickstand. NOW....after about 24 hours I've got a nice pretty puddle of red oil on the left side...NEVER has this leaked fork oil until now. I wasnt really in the mood to replace fork seals, so now need some advice. Are the seals really bad or the fact the bike is leaning more pressure on the left side causing the leak? Where do I go from here.
Thanks for any advice.
silverheli2000 said:
......I recently did some minor work to the front end which resulted in taking all fork covers off, cleaning up the forks, new headlight mount/headlight, and small cafe bars........
Sounds like you may have done something to the seals in this process. Scratch / sand / gouge the fork stantions?
What Yinzer man said - fork seals shouldn't leak. Period.
Yeah...figured. I'm just really curious how they never leaked until I started to use the new kickstand. I can't see how any of my work could have effected the seals, all I did was took the covers off and stuck them back in the tree. Thanks again, kind of a moot point just thought it was a bit odd.
Now that I think about it...while up on center stand (the only way I've known it up to this point) very little pressure is on the front forks...meaning no leaking. Side stand = more downward pressure = notice seals are bad.
