fork options for 1965 s65
hondas65
Hi, I have 1965 Honda s65 that I just picked up with bent forks. What other forks fit the neck. Maybe cb125 or cb100. I would like a disk brake. Sorry I'm new to this.
Not really sure what the steering tube looks like on that bike, given it had the stamped steel forks, but chances are you could make any telescopic fork front end off a small cc bike work well. Some closeups of the steering tube on the frame along with the stem that held the front end on would be useful.
Then all you need to do is measure the inside diameter of the steering tube where the bearings would be and the length of the steering tube. Just need to make something fit, either with just a simple bearing swap or possibly by taking the stem from the old forks and fitting it to the triple tree of some new ones.
I'll get a close up pic of the steering tube when I get home. I was thinking the front end off of a cl70 would work.
Really tough to say honestly. Best bet is if you have a salvage yard near by and can get your hands on some trees to try out - even if it means throwing the S65 in the back of the car and taking it with you. It's certainly small enough :)
If you Google some of the smaller bikes like the CB100 etc. you might find specs on the steering stem to compare to yours. Do you still have the bent front end?
A pic of the steering stem area would help a bit too. But it's going to be a bit of trial and error, unless of course you go the route of getting another matching front end. But if you want disc etc. then ultimately you can make just about any set of forks work. I'm putting a GSXR inverted front end on my XS650 with a Suzuki GT750 4LS drum brake hub on it, as an example.
Well I picked up a set of triple clamps off of a 1972 cb100 and they fit perfect. Now for some 27mm forks and a 17 inch wheel.
