fork reassembly, something doesnt seem right (cb350)
boomshakalaka
Over 1,000 Posts
Im putting my rod type cb350 forks back together and while Ive got one fully together, something just doesnt seem right. When I depress it, it sounds like a really old box spring mattress. It doesnt have oil in it, so maybe this is the problem, but I think its because the spring is rubbing against the inside of the upper tube. I took some pictures of the partially assembled second fork so you can see how tightening the lock nut fully seems to compress the spring too much so it bows out to the side causing it to rub the inside walls of the upper tube.
does everything seem alright here?
anyone? What Im worried about is how much the spring deviates from the dampener. But maybe this is just normal and the noise will go away when I add oil..?
add oil...
mine did that too
