fork tube interchangability
VonYinzer
Over 10,000 Posts
My 73 cb500k came with 6" over fork tubes and that sucks. Have a friend with a 78 xs650 that hes turnin into a chopper. Long story short, i need to know if i can swap the tubes out. The're both 35mm diameter and the length is right. I dont know about the internals though. We would just swap out the complete legs but the brake setup is not compatible and i dont want the mag wheel from a yamaha on the front and a honda spoke on the back. That would be stupid. Anyone know if i can just swap out the tubes? This is the last big thing i need to figure out to get my bike to the point where i can finish it up. Thanks for your help.
I think that all the information that you will need will be here
http://www.armbell.com/kz400/viewtopic.php?t=2299&mforum=kz400
thanks, thats a ton of great info. ohio cafe racers has a similar listing. i know the fork tubes are the same diameter, 35mm, my question is can you use xs650 tubes in cb500 lowers? i was told that you cant .
yeah, i had someone look at them and try to swap them out but he said they wouldnt work. thats all he said, not exactly a mechanic. ive seen bikes with different tubes / lower legs so ill look into it myself. thanks.
