Fork Tubes Issue...
Rocan
"Long after I rest, my steel will live on"
For a long while i believed that the fork tubes available from cycle-x-change would be the same as what i have... today, right before i ordered them (thank god) i read that they are different. When i purchased my front end i was told that it was off of a cb450, no year. I now get the feeling it is off an early model (k0, k1, or k2) cb750, because of all of the circlips and bushings present. The right fork tube is totally fucked and pitted and pretty much destroyed on the inside, so it needs replacing. Now im looking for a place to get them. i messaged forks by frank and i hear that he has them but they are pricy... any other sources? i read a bit on sohc4 that you can use the newer style forks with the older lowers, but it didnt say how. the bushings and circlips are in decent enough condition. Hopefully one of you guys can point me in the right direction... i really dont want to get a different front end. can anyone confirm that this is in fact an early model cb750 front end and not a cb450 front end?
also if you guys know whether or not progressive springs will work with these forks would be a big help to me.
Sounds like you have early or CL forks?
If you want to use late model tubes they are probably going to need a bunch of machining to fit damper pistons. (relatively simple but probably expensive if you don't have a large lathe)
Late model 450 uses different sliders with smaller inner diameter and parallel tubes.
You could look for hydrualic repair shop and have originals hard chromed and re-ground, may be cheaper than new?
PJ
PJ
ill post some pics tomorrow... im really not sure what they are...
i hadnt thought about going to a hydraulic repair shop... ill have to look into that.
bikebandit makes me think that the forks i have are off an early model cb450... same design and bushings. also, the forks did come with the rubber fork covers now that i think of it.
so heres the question...
where can i find some fork tubes for an early model cb450 in mint condition?
anyone? i really want to get these forks done. definitely early model cb450 forks...
Early CL forks in mint condition....never gonna happen. Maybe some repros but you'll have to throw down the cake on those.
I have a set of CB500T forks in damn near perfect condition if you can't find either replacement tubes or an economical way to have yours redone. 35mm, should be pretty much a slam dunk drop in.
check your private messages... ;)
forks by frank quoted me 259 for a set made fresh by them....
im really considering it... either that or im getting swaggers forks if they arent rusted at all.
