FunJimmy
Sav0r said:What size shafts do the Fox have versus the Werx?
Works = 1/2"
Fox = 5/8"
Why?
Sav0r said:Oof. Send them to me and I'll bleed the pressure off them with my shock tool. I have nitrogen on hand should I need to charge them up. I'll do the work for free, just pay shipping.
Sav0r said:I can see where you are coming from and I'm sure you spent some serious cash on those, but it would be a simple fix.
xb33bsa said:ideally you want a dual spring LASHUP something like a 250 the shorty one and a 140 the the long which goives a 80/140 rate the bonus being a crossover spacer can be added to tune when the 140 kicks in or whatever rate you choose on the long spring instead of waiting for the short heavy spring to coilbind
the gas pressure indeed carries weight but typically on a decarbon style design (your podiums)is only slightly very slightly progressive and is not a contributer to spring rate in the way a spring is because of that
very easy to calculate how much load the ressi or emulsion pressure will support
for a 1/2 shaft multiply the pressure times .2 @ 250 psi = 50 lbs of simple load support at the SHOCK per shock this is not factoring slr
for 5/8 x .3 250 75lbs support at the SHOCK per shock
but the volume at about 3cc's per inch of 1/2'' shaft travel is slight compared to the ressy gas volume hence not a lot of change
thios is why an true airspring shock has to have a large shaft it would not change rate enough in travel otherwise
an emulsion shock will have a bit more change in gas spring effect cause they are filled without too much extra room for gas,just enough plus a bit
it helps to calculate the SLR you have by my eyeball a 1.2-1.3 slr, the shocks see 1.2 times any weight loads is what it boils down to
and you can also play with the calc formula seen in the images it seems to work accurately for longer travel off road bikes that i have used it for
there is a nice graph on dual springs compared to straight rate
FunJimmy said:Ya it might be an easy fix but at this point I've lost all confidence in Fox. If they're that far off on spring rate how will they be in the dampening circuits? Wouldn't they also require pressure charge valves to be installed?
Thanks again
Jimmy
Sav0r said:I was thinking that they were needle type inflation? I tried to find a manual for them but no dice.
As far as the dual rate springs are concerned, I think they are old technology. New dampers can control high and low speed movements in unique ways. As a result dual rates springs really aren't needed or even advantageous. They are a bandaid fix for a problem that we no longer face with modern damper technology. I think Work's continues to sell them because they look cool.
dont go fiddlin' with the gas pressure an any shock that is a terrible idea suited for the uninformed at bestSav0r said:I was thinking that they were needle type inflation? I tried to find a manual for them but no dice.
Sav0r said:It absolutely is a tuning feature. Granted the uninformed should avoid playing with it, but for those who have educated themselves changing reservoir pressure is an easy and effective means of change. Anything over 80psi and you greatly reduce hysteresis and cavitation. Greater pressure reduces hysteresis further but has little effect on cavitation. But with dual shock suspension where you see close to 1:1 motion ratios adjusting spring rate via reservoir pressure on two shocks can have a huge effect, especially in this case where the shocks have very large shafts. There's no arguing this, less spring rate would help here and it would have basically no negative effect on damper performance.
xb33bsa said:it cant factored into spring rate directly , only in the initial static rate from then on only testing or calculating the gas spring effect can be used accurately to add to the spring rate
a shock with a 1/2" shaft dia supports 50lbs at 250psi it does not add 50lbs to the spring rate it will add some but very little maybe 8 or ten
as you state correctly it depends on the compression ratio a 1/2 shaft at 3cc per inch would need a very small tiny gas volume to work against to bring the gas pressue up to 500 psi in the next inch of travel from static,then 1500 the next inch that just isnt happening,it is just a factual example of what would need to happen to add the 50lb value to spring rate the volume of any gas shock is too high in the res for much change at all to be usable
the mfgs set their shocks at a pressure that has been engineered to be good in all conditions with included i am sure a very large margin to allow for even some minor leak-out
but it is not a tuning tool
