From First Kick to No Kick - Points/Ignition/Timing or Worse
heyron
For whatever reason, it would seem my 69 CB350 has decided to stop turning over entirely. Just last week it was running fine. One day, after removing and replacing the exhaust to better access the clutch plate the bike just stopped starting. First in the right cylinder, then altogether.
Plugs were a bit black but I'm now compensating for this with a bit more air through the carbs — strange as I'm running higher-flow k&n style cones.
I retuned the timing for the first time using a light and got it spot on to LF and F. From what I've read online and in manuals. I'm doing it right.
The last time it started, it would cut out as soon as I gave it any gas unless I creeped up the throttle suuuper slow. After that it just ceased to come to life. As a precaution, I've cleaned out the carbs, adjusted the air screws, and installed fuel filters.
For the life of me, I can't figure out why the bike has gone from being a strong and easy starter to plain dead in the water.
I've got power at the points, at the battery, headlight, you name it...
Suggestions?
Battery is the most likely culprit. Try some jumper cables from your car to the bike (do not have the car's engine running when you do this).
The Honda twins are notorious for dropping to one cylinder when the battery is close to dying.
Thanks for the input. Looks like this may have partially been the issue but primarily a clog in the right carb.
I JUST purchased a new battery but the acid levels have dropped dramatically. I've refilled them with excess acid that came with the battery but it seems to have dropped once again - this time I went the distilled water route.
Dropped the battery in at 11.5v just to see what happens. Strong spark on the left, no spark on the right (taking a hit and just putting my pinky in the spark plug shoe) Any suggestions as to where to go from here?
11.5V is closing in on a dead battery. 12.5V is what you want to see on a good, healthy battery.
If you're boiling away the electrolyte, it might be time to look into a new voltage regulator. If you can get the bike running, warm things up and measure the voltage across the battery terminals. At idle, you shouldn't notice too much of a difference, but let us know how much voltage you're getting at 5000 RPM.
Yup what sonreir said.
My 350 would do exactly that when the battery was low. (run on left only)
11.5 is pretty darn low. Put it on a charger and get it up to spec and try again.
