JRK5892 said:no i did not use the pull type... my brake switch is in the drum... so i do not have use for the push pull switch, if i was to use it i woudl just hook up the wire and leave the switch on the perch from the rear sets. either way would be easy to run... depends on your rear sets but you should be able to make a perch out of an angle bracket pretty easy
aye see
