front disc brake problem
mrhondada
so I'm probably retarded but I have ran into a speed bump. I took my front wheel off for painting and my shop mate started activating the rake lever with the tim off. now the pads are pages together and I can't get them apart. I'm tired and probably looking into it further than I probably need to. but any help would bee greatly appreciated. my pads are seized with the front rim off. how do I release them. I've bled brakes but no go.
Clean the pistons thoroughly, then stick a screwdriver in there and pry the pads apart.
Read this page on how to clean caliper pistons. This procedure must be done any time you change pads.
http://www.lyndallracingbrakes.com/service_tech.htm
If your pads are pressed together, you'll probably chip them with a screwdriver, I've done it before. I'd just crack the bleeder, and gently push them back in. Then bleed. No biggie.
