Front end inspection. Post accident.
loudest143
Insert sense of humor here---->
I've most certainly got a guardian angel with a twisted sense of humor. I bought my Dynojet kit, got it installed, balanced out the carbs, and took a friend off to a small get together at a mutual friends' house. Guy at the party backs his new BMW into my bike, and breaks the sidestand off, and my bike is lying on the ground pouring gas outta the tank. Unfortunately my bike got hit, fortunately I wasn't on it when it happened. My life story in a nutshell.
Bike ran fine all the way home, cosmetic damage to left side engine case, tank covered in gas stains. But the front end seemed a little off plumb.... Left hand was farther forward than the right hand on the ride home. No rubbing, no binding of brakes, no flopping of bent tires or rims. No visual damage other than a big scuff mark on the paint on my right front fork tube. (bottom half.)
I need to inspect my front end, specifically the forks, but I'm at a bit of a loss... Where should I start? I was thinking after I get my stand welded tomorrow, that I should support the bike, get the front end loosened up and make sure I get get it back square again. If this was a BMX bike, I'd be all set. Grab the front tire with your Knees and twist the bars!
Learned panel, what things should I inspect and look for? The tubes didn't appear to be bent, but that was very early this morning before I went to work. Any input is welcome.
Thanks.
loudest143
Did he actually back OVER anything? Its possible that your handlebars are bent from the fall. If thats the case, buy new ones. Straightening them will weaken the metal. No point in taking chances there. For the forks, the best way I know is to grab a true straight edge like a builders level, and run it around the for tubes (removed from the bike) with a feeler gauge. You should/could see some damage to the chrome also. Theres a lot of things in the front end that could be skewed. How hard did he hit it? Broke the side stand off? Id have to see it in person, but you may have something serious but small and hard to judge going on.
Read your post again...
A front end doesnt just come out of square... If one fork is further forward than another, one is bent. Or the bottom tree could be broken, but if thats the case I doubt you would have made it home.
might not be "out of square" but just twisted. could very well be the bars too. my front end was tweaked after someone kicked it over (long story) i find it easier with 2 people, but i cracked loose the top and bottom trees, headlight, and wheel. had a buddy hold the bars straight while i twisted the front wheel straight again. voila, all good again. if its not that, or the bars... you might have a serious issue.
i have a set of 550 forks that were badly bent in a head on collision, with no damage to the chrome. and i mean badly bent.
He didn't actually back OVER the bike, fortunately. He's got a Suzuki sized dent the height of his whole bumper where he whacked my fork though. ;D Somehow, that does not bother me one bit. ;D I did do one anal retentive thing when I pulled my forks off for painting last year.... I marked with a sharpie on the uppers where they line up with the triple. So when I reinstalled them, I could twist them around to the correct markings, and it went together perfectly. I'm gonna start by checking out those marks, and see if anything is out of whack there. Then loosen the front end up, and make sure it's all realigned properly.
Yay. 65 degrees and sunny today. Fuck that guy. Remember, it's not revenge, it's PUNISHMENT.
loudest143
