Front end swap on a 77 suzuki gs400
kingbesus
Ballin' on a budget
New guy here looking for some help. I just got my first bike and I want to to upgrade to discs in the front. Will the setup off a gs550 work? someone local is selling a gs550 front end and I want to know it will fit before I buy it
Are they selling the triple tree as well? Check the sizes on the steering stem bearings for each bike, but I think would be a fairly easy swap.
It really boils down to: yes, they will work. But it may not be a bolt up type deal.
The guy is selling the triple trees and forks. I don't really know too much about bikes yet and kinda wanted a direct swap
GS400 right through to early 90's GSXR run the same steering bearings. The stem lengths may be different though - which means it may not be a direct bolt-on fit without a spacer or stem swap.
+1 on an AllBalls kit. Ive used them a few times, no issues. one kit was missing the spacer, so they mailed me one that day. great customer service. conical bearings are a good upgrade anyway.
This is perfect. I just got a 77 GS400 also and am looking to do the same exact thing. Let me know how the 550 front end works out!
Going to a GS550 front end isn't an upgrade
A late model GS500 twin cylinder would be as it uses larger diameter fork tubes
Just working from memory, but the GS400 has 33 or 34mm forks, the GS550 has 35mm, and the modern GS500 has 37mm forks.
Problem with the GS500 (if you want to call it a problem) is the 17" mag wheel up front.
The GS550 forks and triple tree will fit directly on your GS 400 calipers fender will work too you may have to shim the axle and calipers if they are wider
