Front-end swaps on '81 SR250?
I'm looking to swap the front end on my 1981 SR250 for something a little beefier in the fork, brake, and rubber departments. The stock setup is pretty spindly, and I'm fairly certain all the fork oil has leaked out years ago! Here's what I want: shorter forks to lower the front end and shift weight balance further forward; single hydraulic disc brake to replace the anemic drum; 16 or 17 inch front wheel to fit sportier rubber than the current 19" hoop allows. Anyone know of an easy direct swap (either using stock triples, but I have no idea what diameter the fork tubes are, or with new triples and steering stem) that would achieve these goals?
Thanks!
Well, I tried searching on here but wasn't able to find exactly what I'm looking for. SR250 fork tubes are 32 mm I believe, and I found a list of steering stem bearings from other bikes that would fit (although no mention of stem length, which would throw a wrench in that plan). I'm not sure of the axle size, maybe it would be easier to just swap on a wheel of the right diameter and stay with front drum brakes? A smaller front wheel might solve the ride-height issues as well, without swapping to shorter shocks.
Any help would be hugely appreciated!
