Front end wiring ID
neevo
Over 1,000 Posts
Test fitting my wiring to make sure it all works with the new bike layout. The front end didn't come complete so I am looking for some ID help. This is the cluster:
I need help knowing what goes into the group of connections that is in the 1. rubber boot 2. Connector 3. Cluster
1.
2.
3.
I assume this cluster is mounted in the headlight?
Thanks in advance.
Can't tell what #1 is until you slide the boot down a little. I think #2 is the connector to/from one of the hand control switches. And #3 does go inside the headlight bucket - is that what you were wondering?
Do you have the factory wiring diagram? If not, it should be available on oldmanhonda.com.
Rich I will snap a photo of the boot pulled down. I thought the hand controls were fed from the headlight bucket, the controls themselves don't have a connector block, only wires.
There seems like a million connections for the front for only the switches, gauges, lights and indicators. My Haynes manual isn't much help either.
It's been a while since I messed with Honda wiring, but as long as nobody has messed with it you can trust the colors. Red to red, green to green, etc.
First up... sorry everyone. Looks like I should have pulled my head out of my arse and done some homework before coming on here and crying for help ;)
Turns out the manual is very helpful and if you do a bit of homework its quite easy to work out what is going one. First step was to remove any eroneous wires, this cleaned up the tangle quite a bit and left a reasonably easy to identify cluster to trace on the diagram in my manual:
First up is the block. Checking out the wiring diagram it is obviously the ignition key. Of course! Problem solved.
Pulled the boot back to find these:
Looks like these are the wires for the switch blocks (left & right) & horn. Another mystery solved.
The headlight bucket wires were tidied up and I was left with not much:
These feed the indicators (left & right) and also the bulbs for the tacho, speedo, light cluster (x5 bulbs), headlight (x2 bulbs) and clutch switch.
In addition I have these 2 wires:
These seem to belong to the front stop switch. Something I don't appear to have. Can anyone show me what this is supposed to look like?
IIRC, the switch is inline with the hydraulic hose. Should be mounted on the lower part of the triple tree?
Ahhhhhhhhh! I was thinking of a kill switch for the ignition, not the front brake switch. Excellent, thanks.
Rich, I am getting one of those Acewell units to replace the clusters:
url
What should I do with all the extra outputs for the original bulbs? Rip them out of the harness or just leave them?
How many extra wires are you thinking?
Personally, I would keep them unless you are going "all out losing weight" from the bike. Just cut the connector off the end of the wire (about 2" from the end), put some heat shrink tubing on it to cap it off, then wrap it with tape. That way it will be there waiting if you ever want it in the future.
Good idea, I like the abililty to revert back to normal if required. Maybe the next owner would want to do that.
Another question about wiring the Acewell. On a few of the connections it says to connect a -ve (oil pressure and neutral switch). How on earth is this supposed to work as the +ve carries the signal surely ???
Double check the wiring diagram - I think both of those are negative connections. The positive side of each light is constantly on (or at least with the ignition switch on). Then when the tranny is in neutral, the negative side of the circuit is completed, lighting up the bulb.
But with the Acewell sometimes you can switch around 2 lights. When I installed mine, I think it called for a + wire for the oil pressure light and a - wire for the hazard lights. So now my oil pressure signal (negative) is hooked up to the hazard light.
Just double checked the diagram in my manual and it looks like you are right, both of the Neutral and Oil Pressure lights are negative connections. Problem solved :)
