Front fender as rear fender
jfsebastian
Guys I need help
How do I get around to mount my front fender as my rear?
What options do I have?
Anyone who made a bobber might sit on the information (if you have a rear fender). I have four places to mount the bracket as I see it.
1. Battery holder bracket
2. cross bracing between right and left side of frame
3. swing arm
4. frame near shock mounts
Any ideas?
Here is a picture of how I want it to look.
JF
Do you have access to a welder? If not cut and drill some holes in flat stock, cut off what you dont like on the fender, make new holes and mount. Thats all I can suggest.
Good luck.
No welding I´m afraid.
I just don´t want the thing to rattle and move around while driving.
Any ideas on how to make a hugger without horrible bars all over?
i like to mount it to the swing arm so it flows with the wheel but you can drill the inside of the rails and thread them... then just run bolts from under the fender into the frame... that will lock it all in there for you
Do you just drill holes close to the lower shock mount and have a a bar around the fender or what?
I will consider mounting directly to the frame, if I can get the lines I´m looking for.
Building bikes is like porn, I need pictures or videos to get it. Erotic novels don´t get make it for me....... ;D
man i would love to show you... but none of the builds i have going on right now have this type of set up... besides i would prob weld it and then fill it all in so that the fender becomes part of the frame for a smoother cleaner look
Thanks guys for the advice. I will think about what I want and which is the best solution for the moment.
Ass soon as I´m done, pics will be published on my blog.
Tomorrow I will paint my swing arm with POR-15. We will see how that turns out.
Thanks again JF
