SeattleRod
After changing the oil in the forks, the fork ends sit wider than the wheel axle. The only way to clamp the axle onto the forks is by clamping one side and then force the other fork inward while clamping it. The difference is about 10mm.
Are the forks bent or am I installing the wheel wrong? Thank you guys, and girls.
These are when the wheel was installed by forcing the forks into place.
