Front shocks on 360 vs 350
Finnigan
Over 1,000 Posts
Hey everyone,
I have 2 pairs of front shocks (one from a 350 and 360), I want to use the 360 shocks but need a seal from the 350's. Here's the issue: the 350 shocks dont come apart the same as the 360s. Top and bottom bolts off and the spring is still compressed between the chrome outer tube. Does anyone know how to get these apart, or maybe have a diagram showing the disassembly? I can post pictures tonight if it helps...
Thanks
They are forks not shocks, maybe someone could connect you to 440v, then you'll know what shocks really are ;D
If you need seals, get a new set, they are not re-usable once removed
They are front shock absorbers, how is a single tube called a "fork"? Together they form a fork yes
Re: Re: Front shocks on 360 vs 350
It is a fork tube. Not a shock. Pj is correct on this one (and most things). Technically the old bikes dont have shocks. They have forks and coil overs. But who is arguing semantics :P
Ok here are pics of the FORKS ;D The top nut popped off the 360 shocks but here it doesnt. The second pic is the bottom with the 360 plunger (?) laying next to it to give an idea.
None of them ever had 'shocks' they have dampers and springs if you want to be semantic
There is a lock nut/spring seat on 350 fork, you have to get a spanner on it (or 'wrench' for 'foreigners' ;D )
It's the bit with the flats, top nut is really two pieces
Hold that and unscrew top nut.
You may find it easier to put a deep socket in bench vice, hold top nut in socket then unscrew lock nut (I find that easier than chasing fork around)
Thanks to PJ I got these out.
There is no seal on the 350's that was missing from the 360's so now i have 2 good halfs of 2 sets of forks...yah the plan now is to use the top of the 350s with the bottom of the 360's. I dont think there will be an issue since the bottoms of each both have the same inner diameter. And since the bikes were so similar I dont think there will be an issue with dampening or spring force, especially with new seals and oil in the dampened fork spring (do i have that right now?)
The seals are in the top of slider.
If I remember right you have to remove the chrome covers on 350 to get to them?
The seal is a ring that went where i circled in red, the plunger below it is the one from the 350, there isnt even a notch for it to go. Thats why I want to use the 350 springs and plungers
That's the damper piston seal, the 350 is on the end of the rod inside the tube
You should be able to get some Teflon that will fit, I may even have some here?
