Front Tire Removal
dtour76
So its time to replace my tires. I have a swingarm stand to remove the rear. How do I lift the front end of the bike to remove the front tire? My exhaust runs down the middle under the frame of the bike. If I buy a motorcycle jack, will I have to remove the exhaust every time I lift the bike? Does anyone have any useful tricks to lift the front end of the bike up?
Welcome to the world of 4-1 exhaust. Carpy sells a frame stand specifically made for 4-1 exhausts that can be placed to raise either the front or rear.
Or, jack stands under the frame will work too. Just set the right jack stand while the bike is on the side stand and use a regular jack to lift the left side of the frame high enough to set that jack stand. It's a pretty sturdy method.
Throw a eye bolt in a stud in the ceiling of the garage. Run a cinch strap from the eye bolt to the top triple tree or straight to the frame right in front of the tank if there's room. Pull it tight and ratchet it until the tire comes off the ground. Hey, it's worked for me about half a dozen times.
I have been known to just stick a scissor jack, (like comes with most cars these days,) and I put it under the frame near the front on the right. I lift the front wheel with the bike still on the sidestand. The bike will have three contact points with the floor, the rear wheel, the sidestand, and the jack.
Make sure that you do all the loosening of the axle and caliper(s) if needed before you lift the wheel in the air. Just lift it enough to take the weight off the wheel.
I modify the typical scissor jack to make it more stable for this use by welding it to a piece of 1/8" sheet steel as a base, and I use an old bit brace as the crank for it.
