Im having a bit of a weird dellima. Bike was just rebuilt so I cant say 'what did you change last, change it back'. While riding fuel stops flowing out of the petcock so the carbs dry up and kills the bike. I can turn the petcock off and on again and nothing changes, flip from on to reserve and nothing. Ive blown air through the petcock and everything seems to work correctly.
Now, if I pull a fuel line off the petcock fuel will start to flow after about 1 second, if I put the fuel line back on while its running out then it'll fill up my bowls and i'll be good for 5-10min or so, its pretty random. I'll have to pull over pull the fuel hose off pour fuel out put line back on etc. Taking the tank cap off doesn't make a difference so its not a vacuum in the tank.
I do have fuel filters on but other have ran the same ones with great success. I know its not the screen in the petcock because it flows fine once the fuel line is off. I dont believe its a filter because as soon as fuel starts to flow they fill up just like they are suppose to. The only thing I can think of is vaperlock being caused by the filters. I read on another forum that you can prevent vaperlock by cutting a slit in the filter itself and it will still mostly filter. Other than that all I can do it start taking things off (like the filters, then the petcock screen and try to see if anything makes a difference but my issue there is the timing, if I take my filters off I cant see the fuel flowing anymore which then makes it a little hard to troubleshoot.
Just checking to see if anyone else has any thoughts or opinions.
