Fuel flow
motorbikejesus
Burnout?? Burnout!!!!!!!!!
ok 74 cb750 brand new petcock clean tank,, 2 fuel lines with 2 clear filters, the problem is im having the 2 right side carbs arent getting fuel flow to them as much as the 2 left carbs. sooo when i run the bike im getting great fuel flow to one side and not the other,, i can see the fuel trickling in the filter and the other is pretty much filled like normal....... How does the carbs vent for the fuel to flow???? thanks everyone
Im not sure its the same on your bike (it probably is) but most bikes vent through the tank... but if it wasnt venting, none of the carbs would be getting fuel, not just 2 of them...
Try taking the fuel line off and see if youre getting a solid flow through the petcock, it should be a steady, fairly pressurized stream. Let it flow for a minute or two to make sure there isnt vacuum building up in the tank and stopping the flow periodically. If thats ok, start going through the fuel lines and removing them and making sure the fuel flow is good at each point where lines connect. You'll find the problem area eventually.
killerdwarf said:
Lose the filters. You don't need them. The screen inside the tank is filter enough.
If your tank has any rust the in-tank filter isn't enough. Your carbs will get blocked up eventually.
Most tanks vent through the filler cap. Try leaving the cap open and see if this makes a difference to the flow (not while you're riding, of course ::))
Try losing the filters. If they were such a good thing, Mr. Honda would have put them there his damned self. If your tank is rusty inside, clean it. If you have a tank that has been treated with that cream garbage, lose it! I repair bikes, and snowmobiles for a living, and many times customers have brought me their stuff to fix with those stupid little filters on because someone thought they were such a good idea. I take them off, toss them in the trash, and solve the problems that quick.
ok so when i take the line off the carbs fuel flows out of the line very good.. So it is definitly something in the carbs im thinking float level or something is stuck closed, thanks
Ya, that's it for sure! LOFL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Both carbs have stuck closed floats ::)Ya right ::) Lose the fucking pos filter, and problem solved!
Did you check to make sure the filter was on right? There's usually a little arrow indicating the direction of flow.
YES MA AM JK , ITS ALL GOOD NOW, NOW TIME TO GET MY LICENSE ,
