Fuel indicator light, is it possible?
BArTY
Ok, so I ran out of gas in the canyons, for the 2nd time this morning. Getting tired of it.. and yes I try to remember to get gas, but I don't have the best memory, so that option is null. What I was wondering is if anyone has ever hooked up a fuel indicator light on their bike? I have a 75 CB750 and was thinking of running some sort of float or probe in the gas tank that would trigger an indicator light somewhere to tell me when my tank is at a certain level. Can anyone think of a way to do this?
In the old days you could buy a screw in gauge for a lawn mower. I wonder if Honda or someone else would have the same idea? I once installed a float gauge on a water tank for our firetruck. You drilled the tank and shoved these probes in. The lights would show half and empty.
Just an idea. Look around ebay and see if something comes up.
Mike
some cars have a small "sensor" just for the light a lot of Toyota's are like this i suspect the sensor could be modified to achieve what your after, although its going to require some sort of interesting mounting and wire routing?!?!
Yes, there is.
I have a WMD dual needle gauge on my 78 CB. It has everything in it, including a low fuel indicator. I sourced an in-tank sensor from a shadow 1100 I believe (don't remember now) It's just a small barrel sensor that when immersed is closed, and opens when fuel level drops below it. Simple install, had to drill a 6mm hole next to the fuel cap (I have a 'smooth tank, with the door) so install was easy. You could also have a bung installed on the undersidem and mount the sensor as it comes.
However you mount the sensor, run it to an LED on the tree. Simple, really.
hillsy said:
Do you not have a reserve setting on your fuel tap?
I do, but we all know how shitty these bikes run on "ON" I just leave it on reserve. Seems to not want to get enough gas, or a consistent flow of it otherwise.
Yes, this is more what I am after. I'll look into the Toyota sensor, I have a friend who owns a dealership, maybe he can get me one off an older car. Thanks for the info on that.
leftlaneguy said:
Yes, there is.
That's perfect!! Can you snap some pics of your setup?
What you could do is this: Go to the liquor store and buy one of those "airline" shooters, either drink the alcohol or pour it out. You're preference. Get a nipple with adjoining tubing etc. What you want to do is set it up in such a fashion so that you can mount the "shooter" bottle somewhere on the outside of your tank and then connect the bottle to the tank so that when you fill the tank, you fill the bottle. Since it's clear, you'll be able to see the level of the fuel and when it's drained from the bottle, fill it up. I saw this mod done on a rat bike and it was sweet as hell. But, you can use anything for that matter that is nice and small. Just position it on the tank in such a fashion that you still have enough gas to make it to the station.
Another option, though I would end up filling the bottle with whiskey and when it was empty head to fill it back up ;)
This is how the chopper guys do it:
But seriously, why bother? You should have a reserve on your tap, right?
Fuel runs out....turn to reserve.....go get gas....
if your not getting enough fuel with the petcock on "on" then you need to rebuild it.
reserve is there for a reason.
If you want a fuel light, pretty sure it isn't going to be possible without welding a fitting into tank.
I would look for a 'dead' fuel pump from modern sportbike, they have small bullet style fuel level senders, about 10mm dia, 15~20mm long.
Just fit it in tank at level you want and connect to a lamp
Replace your petcock dude. My 79 runs fantastic with it in the "on" or the "res" position. Yours is jacked if there is a difference.
Ya I may need to look into this
I got the idea from a guy who build an awesome cafe racer "rat bike". That was what he used. I plan on doing something along those lines as well. Could always use to right angle nipples with a clear piece of fuel line as well.
