Fuel Line Leak?
shermerrr
So I have a '72 CB350 and yesterday I was cleaning and degreasing the bike. There is a mystery hose that runs down the front, under the engine and then through the swingarm. It was covered in viscous brown sludge. I sprayed the sludge with simple green and the hose literally fell apart. I guess that all the old sludge was holding this hose together and that by spraying it, it just fell apart. I'm assuming this was a fuel line as it is now leaking gas and stinking up my garage. Any idea where I can get a replacement fuel line and has anyone done a fuel line replacement? Is this even a fuel line?
Thanks!
Probably an overflow line from the carbs or (if it's fairly large in diameter) a breather hose.
If it's leaking gas then you possibly left your petcock on or you have a carb issue you need to investigate.
Found the culprit and it was most definitely the petcock. Not only was it left on there was also a tear in one of the vacuum lines causing it to leak like a sieve. Does anyone know where I find replacement vacuum lines? In the picture it's the green line on the right.
That's not a vacuum line. It's a fuel line and it should be going to a carb. The 350 petcocks have dual outputs, one for each carb.
Thank you. Do you know where I can purchase new fuel lines?
Almost any hardware store. Auto parts stores for sure. It's sold by the foot. I'd go with Tygon as the material. MUCH better than rubber.
Thank you, sonreir! Do you know what size works best? Motion pro sells 3/16 tygon fuel lines by the foot. Would that work?
