FULL 17" setup for old UJM's
makenzie71
Specifically built for Suzuki's, but anything with a 15mm/20mm axle setup will be pretty similar.
Asking $250 shipped to the States from Lubbock, TX.
17X3 front wheel
~310mm semi-floating rotors
~aluminum caliper hangers
~Tokico 4-piston calipers
~15mm Axle and spacers
Will need to either run an aftermarket speedo or do some finagling with a speedo drive...doesn't come with a speedo drive. I think the GS500E drive will work, but I never ran one.
17X3.5 rear wheel
~Rotor
~Sprocket Carrier
~All shims and spacers to fit 1981 GS750 (other years/models may need different spacers)
~7500 miles on the 20mm bearings
~Custom 20mm bearing brace
No tires. I can get and install tires are buyer's expense (cost of tires and additional shipping for weight).
I can get a caliper and hanger for and additional $50...I broke the hanger accidentally and the caliper has a stripped bolt. This mod requires a GS500E rear hanger and caliper with the hole bored for the 20mm axle
If you do not want the forks, I'll knock off $50.
