Fully Charged Battery, but Weak Electrical?
wibblee
I left my CB350 switched "on" overnight and the battery was totally drained. It's a new battery, less than a month old, which has never seen the road yet. Prior to my act of idiocy, it had been on and off the float charger and cranking the starter with no problems.
It's been on a regular charger almost 24 hours now and it's showing close to 13 on the voltmeter. When I turn the bike on, I get a super weak neutral light. If I try the horn, I get the start of a weak honk and the neutral light dims even further. Nothing else electrical will work.
I guess my questions are: is this a battery problem? If yes, can I revive the battery? If no, help?
how many amps is the charger..? And is it a sealed batt or not. If not are the fluid levels up too snuff. Leaving a Batt on all night would make it warm enough to evaporate some of the water before it went dead.
Thanks for the reply Louie,
It's not a sealed battery and the water levels are all between the upper and lower limits.
The charger is a 1 amp charger.
Is it possible for the volts to be good, but the battery to be bad?
1 amp is slow but good way to get a charge( if DEAD, could take multiple days). But in all honesty, I would bump it up to a two amp charger.. That still gives you a nice deep charge. But will bring it back to life over night. Hope this helps...
To your last question... Yes, if your powering something than has an ultra low amp draw... Like an 1157 light bulb..
At this point though, with the reading being about 13 volts, does the charger matter anymore?
I'm trying to wrap my head around the good volts/bad battery thing. And people say to bring it into a shop to have them check. What check do they do beside the voltmeter?
If it wont crack you motor . It doesnt have the capacity to hold amperage anymore. they would check it for a dead cell.With a simple check of the fluids.
I'll add... technically volts are not important when it comes too cranking your motor, amps do that. More important too firing the ignition... running lights etc. I'm sure some one that some one with a broader knowledge base will chime in. Mines broad, but even after 20+ yrs... getting broader... lol
