FZ600 forks on a CB360?
mysta2
Over 1,000 Posts
DTT BOTM WINNER
So I've got this 1986 FZ600 that I can't get rid of, but I need it out of the garage (or at least off the work bench) So I may have to just break it down, recycle the big stuff and box up the small stuff for later use.
That being said, the front end is good (so's the swingarm and I may be asking about that later) It's a standard (right side up?) style and for all intents and purposes looks just like the forks on the 360 now.
FZ:
CB:
This is theoretically a decade of technological improvement, but you certainly can't see any of it. What would the difference be? Can one assume that the FZ forks are better and therefore a worthwhile swap just because they are newer? I'd have to machine new triples and fit the axle in the 360 wheel (not interested in the FZ wheels for this bike) The only right off the bat obvious benefit of the FZ forks is that they already have brackets for a fork brace.
One of my friends has already suggested that the FZ forks would be easier to modify with products from RaceTech.
I'd imagine it would be a significant upgrade in stiffness based on the fork tube diameter alone, and likely improved dampening from the presumed improved mechanisms.
With a little work you can probably use the FZ triples - likely have to swap in the CB stem though.
Allballs has a fork conversion tool that will tell you the bearing sizes needed and what stock front ends would work, based on top and bottom bearing ID / OD. They don't consider stem length however.
If you decide to ditch the FZ swinger, let me know :) I could use it.
I'm on the fence with the swing arm. It would "update" the look of the bike a little more than I want, but if I pull it off there and it looks like it will fit without much major hacking I may not be able to pass it up.
Swivel said:
They might be too long.It's far better to just fit different steering head bearings and/or to your old clamps stem to the new ones than making your own trees.Clamps can't just be made safely from normal cheap spec ally.Those newer forks(and clamps)would be about twice as rigid with far better dampening and much more sensitive to small bumps than your old ones.
I appreciate the response but I'm not sure what you mean by "cheap spec alloy". I was running it back and forth whether I'd use 6061 or 7075 and I've decided on 7075 T6 for my VFR trees.
