nastyinsc
I've been searching everywhere online and working for the past 3 days, and I've still got an issue I can't work out.
Back Story: I've been bringing my '72 CL350 up from sitting for a while. Timing is dead on. Point gaps are on point (ha!) Cleaned the carbs and petcock. Right side is running dead on. Left side is a mess.
Before cleaning the left side wouldn't fire at all. Would open the throttle and nothing but sucking air. Popped it out and cleaned it up. Now it runs, but not at idle. Won't click on until about 1/4 lift of throttle.
On top of all this, it's pouring gas. EVERYWHERE. I have a fuel line clamp at the carb and it is still leaking out there and through the bowl overflow. I've set the float height to the 26mm. I think it may be a petcock problem, when I turn it on it just keeps flowing. Like heavy flow.
So, is this petcock? I don't have a fuel line clamp at the petcock itself.
ALSO, I don't have the small rubber plug that goes over the "slow jet" in the bowl. Looks like the last owner thought supper glue and a screw top would work. Dug that all out and now there's nothing there. I have ordered one.
Side note: Thanks to you guys I've learned more about this bike's engine in 5 days then I could ever imagine.
