DasBalddog
Active Member
Okay problem....
Here's one for your WTF! book.
Have been rebuilding a 1972 CL350 Got everything hooked back up, no leaks, no smoke...
Though I did notice that whatever these pipes are meant for (aftermarket), the pipe itself does not touch the gasket (put new gasket rings in the motor) and the left pipe moves if you wiggle it. There was a Spring around the pipe on the right side... Weird.
Oh well.
So, weird ass problem.
Put gas in it with the petcock turned off, no leaks. Good.
Turn the petcock on, (there is only a little gas in the tank) and I can hear gas bubbling into the fuel line, and very quickly I can see it in the fuel filters... thing is, the right fuel filter (connected to one nipple on the petcock) fills up about 15-20% of the filter and stops. The left hose filter fills up completely.
The bike runs, runs pretty good,atleast for a minute, but then I notice the right side isn't running. I notice that there isn't gas in the right filter.... Hmmm...
I turn the petcock off, and take the right hose off, and slowly move the petcock lever, nothing.
I take the compressed air and shoot a bit into the petcock nipple, and then gas started flowing freely. I am like "Hell yeah", and connect the hose again and turn the petcock on.... several second pass by and no fuel in the filter. I slowly pull the hose off again, and the gas starts flowing.
WTF?
It only flows when the hose isn't connected. Stops when I put the hose on.
And then the left side started acting the same way.
Any ideas?
Oh well.
WTF?
Any ideas?
