lonelywolf8588
I think my plan will work but I'm tired of having gas spots on my tanks. What clear should I use? I was thinking engine enamel clear this time.
malloy said:just get a normal can of duplicolor paint, then hit it with the 2K clear. the clear is where your going to get your shine and your protection
i have a plastic tankNINEGEAR said:quick question what dose gas do to plastic
Yep. As long as you dont break through to primer. Nice light coats will help against orange peel, but if you get some just use a sanding sponge with 1500/2000grit wrapped around it (although I think some guys go a little courser, but I'n not sure). Sand till your satisified but stay away from the edges. Clean, then hit it with a bunch of coats of two stage clear. No one will ever know that it's rattle can. There is a great how to paint rattle can in the 800 help section. Hope this helps.slapi01 said:so say you put your color down and has a little bit of orange peel. can you say wet sand (1500/2000) then lay this 2k stuff down to have it glossy. sorry but i am no bodyman.
troybilt said:Yep. As long as you dont break through to primer. Nice light coats will help against orange peel, but if you get some just use a sanding sponge with 1500/2000grit wrapped around it (although I think some guys go a little courser, but I'n not sure). Sand till your satisified but stay away from the edges. Clean, then hit it with a bunch of coats of two stage clear. No one will ever know that it's rattle can. There is a great how to paint rattle can in the 800 help section. Hope this helps.
