Gas tank vent
Finnigan
Over 1,000 Posts
From what I found on the internet it allows gas to flow more freely and restricts the carbs less? Can someone explain this in a little more detail to me?
If your tank doesn't have a vent it will build up a vacuum inside as the gas gets used by the engine. When this happens it'll starve the carbs of fuel and the bike will run poorly or not at all. All tanks have vents but most are just built into the gas cap. The picture you posted is just an external one due to the fact that the gas cap is non-vented. Some older bikes and dirt bikes use that method.
There should also be a "check valve" - ie, a one-way valve in the external line or in the part that screws into the tank, the purpose being if the bike tips over - ie, crashes - the valve closes off the vent line so you don't have a gas all over the place.
Most road racers have them, and some street bikes (GSXR's) too.
The last bunch of tanks I've built have had an outlet for a breather line and check valve bonded into the layup and on my street tracker, which uses a dirt bike tank, just added an Ariete aftermarket breather line / check valve to the existing gas cap's spigot.
Regards,
Pat Cowan,
Vintage Motorcycle Fiberglass
Another reason for some sort of check valve in the tank venting system is to maintain a bit of pressure in the tank. At high temperatures, particularly sitting in the sun, gasoline can generate a fair amount of vapor pressure. If the tank has 2-3 psi internal pressure, it dramatically reduces evaporative fuel loss. The higher octane components of the fuel are also the most volatile, so a tank that is vented to atmosphere will allow the fuel to degrade.
Yes, of course they are vented, just not freely to the atmosphere.
Most flip up gas caps have a one-way valve in them to allow air to enter the tank when needed. That spring pressure that you push down against to latch it is the pressure relief. The recessed ring under many gas caps has a vent hole that allows vapor or liquid that pushes past the spring loaded gas cap seal to be routed under the bike or to a charcoal canister.
Basically, yes.
Having A vent is required, and almost all stock caps have one.
Having THAT kind of vent is generally a race/MX thing.
However, be aware that sometimes stock vents get clogged over the years, so if your bike is only running well for a few minutes and then acts unhappy, the vent could be the cause.
Clear as mud?
Bozz said:
Basically, yes.
Clear as mud?
Quite! Thanks everyone!
