Gaskets and o-rings
laran
Active Member
For motors and carbs, should they ALWAYS be replaced? Or is it a judgement call? Those suckers are expensive.
Hey these nothing worst than puting the engine back together and having big trouble and fiding out that you have to put it back in to pieces because you cheap out on the gasket :)
I would always replace the engine gasket at least... carb if you want, anyway they are more accessible than the engine itself. :)
Are the gaskets and o-rings specific to the bike? Or are they interchangeable among several bikes?
Usualy its only for one bike, only...
But some of the gasket in the gasket kit can be interchangeable but not all of them.
Tell me what bike you have and I'll try to guide you.
'83 CB550SC
joevirus563 said:
Yes it might be a little pricy... but if you open your engine i would do it... :P...
Sheesh, that's gonna be $300-400 just for o-rings and gaskets. Guess it is what it is ...
Find out the part number and search for it on ebay and google. That's what I did and I was able to find them for good prices. Joe is right though, engine gaskets are a must. If yours are still enacted and not ripped or torn you could get away with using gasket sealant on them if money is a real issue. I use this stuff on the new and old gaskets.
Hylomar Universal Blue Racing Formula Gasket Dressing and Flange Sealant
You can pick it up at pepboys. They also sell rubber gasket paper if you wanna make your own but i wouldn't suggest it for big complicated pieces. I bought a roll for small gaskets like my oil plugs.
There are paper/plastic gaskets which aren't bad, they're only $15-20. Then there are metal gaskets between the top and bottom and and between the cases. The paper/plastic gaskets I'll definitely replace. They're in tiny pieces having been scraped off. But the metal gaskets seem fine. Do I need to replace the metal gaskets? They're the one's I'm really worried about b/c they're like $70 each.
As far as the carbs, I'm not sure what I'll do. There weren't any problems with the carbs before I took everything apart. They were just dirty as hell, which is why I took them all apart. I cleaned them up.
The metal gaskets are very important. I can honestly say I never needed to replace mine. I suppose if they look good, flat and not pitted they'll probably be good.
Your carb o-rings can be the difference between good and bad performance. If your carbs have leaks in them then the air flow won't be working like a vacuum, which is how they are designed to work. I just replaced my float bowl rings because they were flat and hard. The last thing you want is gasoline dripping on your engine. I would suggest doing the same.
That's not too bad then. Good news!
