Gauge Restoration?
edelweiss
Coast to Coast
Does anybody know a "go-to" source for getting vintage speedo and tach gauges restored?
Thanks!
John
Decal overlays are quite common, but a full restoration (involving paint and mechanical rebuild) is something quite different. I don't know anyone who does the latter.
http://www.joellevinecompany.com/custompage.asp?pg=calibration&repair
from what I hear, this can be a very expensive ordeal. Talked to a guy once who said that the gauge restoration quotes he got were more than his bike was worth.
Thanks guys. Sorry, I should have not used the term "restoration". I actually just need the inside of the gauges working, oiled, calibrated etc. I actually want to keep the aging/patina on the gauges and faces.
I've split gauges on a couple Hondas, and it's not too hard to get in there and clean things up. Both of the gauges I fixed were just gunked up with grease, so I didn't have to fix anything per se.
Getting it back together properly is a little harder to do, if you're careful when you pry the face off, you can put it back together in such a way that it doesn't look like it's really been fiddled with. I also replaced the weather seal, with several layers of electrical tape around the interior to make everything a little tighter and more watertight.
BUT If you want it to look perfect, I wouldn't risk it.
Thanks! I imagine the mechanism can't be that difficult. And I am getting moisture under the glass (fogging). I prefer the gauges faded and worn (patina). Just want them to function and be water tight.
Thanks again!
John
