getting a saftey
noyko
Active Member
1975 cb360
it has come to that time. i need a safety done.
i am confident that it is safe enough to be on the road. but will they.
is their a place that is better than the rest for the vintage bikes?
any one know a relaxed place that does safetys.
Contact LocoLeon on the board. There is a guy on Steeles between Trafalgar and Winston Churchill who I believe performs safeties. I'm not suggesting though that he'd be relaxed in any way - hard to find that.
What are you most concerned about in terms of the safety?
im most concerned about the side cover gaskets. i put new gaskets in . but it aloways has a small layer of oil at the bottem
could i fail for that??
i actually just talked to that guy. he said i would have to leave it with him for 24 hours. witch im not happy about because i gotta get my buddie with a van to come pick it up and drive it there.
Unless it's pouring oil out, there's no reason to fail for that. Do all the lights/horn work? Brakes are good? Tires good?
Chainguard in place, fenders in place etc.?
I got my first bike safetied in Georgetown at the Firestone dealer - not sure if they still do bikes. A safety inspection does not include starting the bike, so clean it up and haul it down.
That being said you can get a temp permit to allow you to ride the bike with no safety. Is it insured and plated already? This way you can legally test ride it and ride it to the place for a safety.
ok. rookie question, but. . . why do you need to get an inspection? im in CA so it might be a bit different. i thought if the bike is registered with plates and you have insurance than it should be fine. obviously if you dont have certain things like lights then you could get pulled over. are you taking a bike with no title and building a new one with the frame VIN #s? im confused.
i just found the CA vehicle code and wrote down everything that pertains to MCs. said nothing about fenders or license plate orientation.
just getting info before i get into trouble
thanks
Basically any USED vehicle, regardless of the number of wheels, needs to be saftied before it can be registered by a new owner. The premise is to keep beaters from being sold and put back on the streets.
They're looking for basic mechanical soundness... brakes, lights, tires etc all above minumum spec.
do you know what year it begins at? when i registered my '75 cb360 they didnt say anything? def makes sense. anyway, i googled the vehicle code for my state to try to find things that would differ from what i want on/off my bike when im finished. might help you. thanks
California and Ontario laws are obviously different - any vehicle here, regardless of age requires a safety certification.
Here bikes don't need to be inspected... unless you're using it for your road test.
