Getting Close
GySchmit
Active Member
Posted in another thread about my wreck. Was up at the shop this past week and the repairs are coming along. Hopefully will be back on the road and in the wind shortly.
Following things have been done...
Clip-On Bars repaired
Headlight Mounting Tube removed from Fork Tubes
Rectifier moved to Frame (old horn location - Horn previously moved to under tank)
BC Ignition (kit) Relocated to Left Frame Rail
5.5" Chrome Diamond Reflector Headlight mounted to lower Triple Tree
Wiring Harness (previously inside OEM Headlight) re-routed to under top Frame Rail.
BC Mini Brake Reservoir on
Aluminum GP Foot Pegs on (have to tweak as they droop)
Progressive Front Springs Installed in Forks
Progressive 412 Rear Shocks on (with upper and lower caps off)
Self-Modified Chain Guard on
OEM Header Pipes Modified to One Off "TT" Style (cross over pipe removed and holes welded up, Pipes rebent to run "TT" style (tucked up and in (Not like the D&D "TT"s), Pipes Wrapped, Lossa Mini Reverse Cone Mufflers (brushed stainless) mounted.
Kick Stand modified for "TT" Pipes
Tank and Side Cover Stripped, Primed and Satin Black laid for Stripe
Work left to do...
Mounting Steering Damper
Fab mount for Mini Cats Eye LED Tail Light
Mount License Plate holder to Left Swing Arm and wire in lights.
Wheels Trued
Carbs Re-jetted for new exhaus and Balanced
Oil and Filter change
Front End looks CLEAN without all the OEM stuff mounted to it!!! Only problem is that the OEM Gauges look like crap now! Have to start researching another option... (Acewell, ??? - Need Options Here)
Only downers are that (1) I'm not done with the paint! Had to take the Tank & Side Covers back so he can make sure all the wire re-routing will fit. Seat Cowl replacement is Yellow, Tank & Side covers are (currently) Gray Primer with Satin Black (where I plan to tape off for the double stripe) and front Fender is the color everything will be eventually. Going to look like trash till I run the bike to ensure everything is up to snuff and get a chance to paint.
And (2) is that I was running a Fly Screen - Really helped to keep the wind down. With the modifications done to the front end (mostly the new headlight) I'm going to have to make my own Fly Screen/Fairing if I want wind protection. Have to start reading up on how to make Fiberglass parts.
Hopefully in the next couple weeks I'll be IN THE WIND!
__________________
Good news! Hope your body healed as well as the bike seems to be. If you had to choose again, would you take the write-off or go the repair route?
Wouldn't change a thing so far.... well, I probably would have finished the paint faster but I though I had more time. Not a big thing though.
Guess my body healed like the bike... came out better as now I can tell when there is a storm coming in (back starts to ache where the break is). :-\
OH and your avatar looks like I probably look when I launched from the curb prior to the wreck (landing didn't go well!)
Well, figured I'd post in this one final time. Bike has been back on the road for a while.. have put a little over 2500 miles on it. Everything is working fine, no major issues what so ever.
Still trying to figure out what I want to do with the paint. But in the in the mean time I've settled on a, as I call it, "Preping for Final Paint" look (though this is how it will stay :o )(still have to finish the rear seat cowl though) I like it as it seems to fit the bike.
The exhaust, to me sounds great. Living in FL 95% of the bikes around are HDs and 60+% of those have after market (read loud) exhausts... so I don't get any flack with the sound of mine. With the cross over pipe removed and welded up the bike now has that "potato, potato, potato" idle. 8)
Here is a video of what he sounds like. ;D Oh didn't mention in the Video - Progressive Front Springs and Rear Shocks.
http://www.youtube.com/watch?v=L6VFgQwe9hY
