Getting my bike started after buildup.
AzHonda
Coast to Coast
Looking for some advice/help here. After completely tearing my CB360 down and powder coating, painting. I have rebuilt the carbs, new fuel lines, blah, blah blah.......I am having a hard time getting the bike to even act like it wants to fire up.
I have not done anything as far as timing. I didn't break the engine down during the rebuild, just painted it. It fired up before the teardown. I have new points installed (before the teardown). When the LF is at the mark, the left point is open (that's how it should be right?).
Is there something I should have done or should do to the carbs since I rebuilt them? I have a feeling this is my issue. I do get a loud "POP" out the right muffler after to much cranking.
Thanks for any input.
Swivel said:
Can of worms time..........Have you got the coil wires or plug leads swapped around so they don't fire from the points at the right time.Is the points wire inside the cover touching anything?..Has the new paint caused the wiring not to be earthed where it its bolted to the frame,engine.etc....Set up a cheap timing light wire step up (not a strobe light) or a analog multimeter to set the points timing,its an art to get exactly right.Use a multi meter to check the points wires inside the points cover for earthing.Are the points dirty with parts storage oil or have you put the tiny screws that hold the points wire onto the timing plate with the washers wrong?
Provided you didn't change the points any mess with the ignition is some other way, having the coils (or rather, the wires) switched is my guess as well.
OK, I have spark at both plugs. Both smell like gas. Here is what I noticed though and maybe this is part of the problem.
On the right carb, the vac plug is missing and there is alot of fuel coming out and into the air filter on the same side.
OK, that is next on my list. Now are we talking about the two wires that come out of each coil right? And I did put new points on but that was before I tore the bike apart and it was running then with them.
Thanks for the help guys.
