Getting some popping that wasn't there before.
  • Thread starter Thread starter cory.ahlersmeyer
  • Start date Start date
C
cory.ahlersmeyer
Guest
About a two days ago, I replaced all the fuel lines and clamps.
I rode it to the gas station, filled it up, and rode it home.
It sat outside (semi covered) in the rain for a day or two and now it pops something awful, especially under hard throttle.
Anyone have any ideas what caused this? Did some moisture get into the oil or gas or something?
More than likely it got soaked up in the carbs, or may have got into the fuel through the cap. Pour a bottle of HEET or Water Wetter in the tank (follow the dose directions though). If you're cheap, like the rest of us, pour a quart of rubbing alcohol in there and then fill it up with fresh gas. It'll burn off the extra moisture.
Try Jewbaccas idea first , Heet
If your new lines are touching the engine. They may be heating up fuel inside lines causing expansion/evaporation. Believe me...Bubbles can restrict flow causing a lean condition. It will run like this. Hot fuel fumes. but run poorly. Becoming worse at higher rpms. Because bowls cant re-fill properly. i would ASSUME new lines were clean inside so maybe not dirt.
