gl 500 cutting out
pterodactyl
The bike runs good when I first ride it, after it gets hot it will cut out once in awhile. this morning it was worse than usual. when this happens I can give it some throttle and it straitens up. Funny thing is it only happens once in awhile I changed the fuel filter last week, so i doubt if that's the prob. I was thinking it may be a accelerator pump. Any thoughts? How much of a PITA are they to replace on the Honda carbs?
TIA
are you certain it's fuel and not electrical?
I have heard of the gl500 igniters getting flaky... (although complete failure is the more common failure mode)
The carbs are not hard to completely strip, and the accelerator pump is easy to get to.
Fuel cap venting correctly? Does your petcock still have a screen over it? Is it clogged?
Slow fuel flow can sometimes act like other issues...
Yea I pulled the the trap off the petcock this morning and the fuel is flowing good. I'm using the same cap. I got it new last summer. What ever it is, it's gradually getting worse though.
The petcock does still have the screen and I think that's the problem. I was starting to think it was the primary jet. I was riding today and I switched to reserve and and it ran good. The petcock is less than a year old so I didn't think that could be it. I'm thinking about getting rid of screen all together. Thanks for the reply Bozz. If your ever in NM I'll buy you a beverage, and screw the rest of you guys J/K
