Goldwing coil pack
New to the form. working on a gl1000 cafe project.
Got the bike dirt cheap, woot, and was told when it runs and gets warm it shuts off because the coils are bad... does this sound right? I am mildly inclined with cars, never wrenched on a bike before this , so I have no idea, thought someone here would know.
2nd question, buddy of mine has a longterm project with a cb750. He offered me his coil ( if it will work) and Im wondering if it will cause any issues? Also, on Ebay, finding the exact model year coil has come to no avail, will another set work if it is off a gl1100 or similar? dont want to buy a part and fry my new baby.
thanks for the help!
i'm not literate enough about bikes to comment on your first question, but i'll take a stab at the second point to hopefully get you headed somewhere in the right direction.
so far as i understand it, coils are pretty much universal so long as you get one which has the right resistance for your bike. i'm just browsing over at DCC and they sell 3ohm and 5ohm coils for singles/twins as well as for four cylinders. if you can find out what your original coil(s) resistance is rated at you should be able to find a replacement fairly easily.
with that said, replace all coils at the same time to make sure you've got even spark across the cylinders.
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-ignition-parts-universal-12-volt-ignition-coil-24-71512.html
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-ignition-parts-universal-12-volt-ignition-coil-si-165-2.html
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-electronic-ignition-parts-universal-12-volt-ignition-coil-si-47.html
on the same page they've got Dyna coils listed for the same applications at 3ohm or 5ohm for singles/twins as well as four cylinders. they're a helluva lot more expensive though.
www.randakks.com/ everythng you need to know about GL1000 ignitions and pretty muc everything else. This site is a bible for me when I need to figure out an issue with my 79. ALso NGWCLUB.COM is a must.
Cheers.
Before you spend money on coils, did you confirm that it shuts down when hot and are you sure it's not just a blocked breather hole in the fuel tank?
The way your post reads, it sounds like "the PO said..."
I saw the title of this post and thought "oh shit! someone else with goldwing coil problems? I should tell Demetri about this" then I saw who posted it... Carry on my friend! :)
As a note in case anyone ever runs into something similar. They were automotive wires, badly pliced, producing almost no spark when we tested them. Got the coil pack, installed and it fired right up. We couldnt get it to keep idling , had to hold starter, then realized that minor detail called the pulse generator wasnt hooked up, oops. Problem entirely fixed! Almost on the road!
