greetings from Michigan!
620dark
You can always get it running with time or money.
Hi folks,
I found this forum while doing some research on a '79 CB650 that ended up in my lap. Even though it's a red headed stepchild of a bike, I still think it would look pretty mean with some work.
Anyway, I've been working on cars forever and had a cb450 when I was in high school. Now that I'm older and dumber, I'm back on bikes.
The 650 was too cheap to pass up, but the ignition modules are melted, and that's apparently due to the coils being shot. I'm working on the GM HEI / GM coil conversion, and have overhauled the carbs as well. I wound a new rotor coil, as the old one was reading about 2 ohms. I've been able to get it running for an extended period of time once, but that was before I made the new rotor, and it died when the battery ran down.
I'd love to hear about or see any GM HEI / coil conversions that others have done - I'm not sure where to mount the coils as I don't think they'll fit under the stock tank. I've already fabbed a mount for the HEI units under the seat where the stock ignition modules used to live.
After I get the bike running reliably I'd like to install some clip ons to replace the awful stock bars and go from there. I like the look of the stock tank, however, so I think that will stay.
I'd love to hear any suggestions or ideas you have - this looks like a great place to learn from some real experts!
Oh, and here's a picture of the 79 cb650 in question - I love those Comstar wheels!
Welcome from Indiana! The Michigan line's not too far from me. I'm seeeing lots of potential in your project. Takes a twisted guy to admit he loves Comstars. I'm right there with ya. Most people don't care for them for some reason. ::)
Look up GS Pete here and PM him, I'm thinking he did an HEI module... on second thought maybe it was a regulator for the charging, hell I can't remember but it's worth a shot. ;)
The Comstars have some '80s "future of the past" vibe going with me that I like. But then again, I liked "Blade Runner" as well.
I dropped in the new HEI ignition module I built, but I've got to mount the GM coils and build some custom GM -> Honda spark plug wires. The Honda plug boots are in good condition, so I'll be able to reuse them. I'm just hoping that fixing up the ignition is what I need to keep this thing running strong.
Welcome Dark. That thing is a little lacking in the fine aesthetics department, but it's more or less complete, so it should be a fun project. People will tell you that if you want to make the world's coolest cafe racer, that's not the best place to start. If you can't have the bike you love, love teh one you have. Right?
There's a guy on a Kawasaki triples board that replaces tons of Pertonix units with GM HEI. I'm sure they work fine, but with off the shelf units available, I can no longer be bothered making something work. Doesn't men you shouldn't though. :-)
Did you give the whole thing a complete service yet? I'd give it a comprehensive stem to stern check out and flush old oil etc. and clean out the gas tank and petcock to remove rust and traces of old tar in there.
I know you'll fit new tires before you take for a fang and the brakes will be checked/repaired.
Have you been up to Grattan for the AHRMA weekend. Not exactly cafe racers but the same era bikes converted to racers.
The tank is spotless inside. Eerily clean inside - I expect some horrible other problem, like black widow spiders riding on the back of scorpions riding on the back of duck billed platypuses.
I've rebuilt the carbs after a nice hot soak in PineSol, and went through the brakes. Of course, after going through them and putting fresh fluid in the system, the caliper seals started leaking and the master cylinder reservoir began leaking, removing the remainder of the crappy paint from the tank. Sigh, both of those will need new parts.
The engine has 8,xxx miles indicated on it, and seems in fine shape. I guess I'll know for sure when I get it running reliably...
Hahahaha.......Might be a redundant question but, did you replace the piston in the caliper?
No, not yet. That will probably be part of replacing the seals, though normally I can get away with just replacing the seals on calipers.
I was able to get it running a little better after getting the GM coils and ignition modules hooked up. I still need to come up with a real air filter because it runs like crap without that to richen it out. Closer and closer, though...
I've started a build thread...
http://www.dotheton.com/forum/index.php?topic=35881.0
