Re: CB750-F3 'Filthy Beast' - Ground Resistance Resurrected
Ok, been a while, but it has been an eventful day.
I ditched the sling and small pad seat I sewed up. Too damn small. I did however build it's replacement. I started by lowering the profile of the rear and scooting it back a bit. I also welded together a tube frame, and a half ring trim to attach the seat back to.
The seat pan is connected at a hinge point:
The rear ring got attached to the same point. I might throw the electrics in there, minus the battery of course. I'm also thinking either a strap with custom buckle to hold it closed, or a latch of some kind. Maybe like one off a vintage ammo can. Hmmmm...
For the sake of simplicity I'm gonna cut some outdoor plywood to shape, pad, and upholster it then mount that for the seat and 'backrest'. Should be easier than a metal pan.
Since I'm keeping the stock oil tank, it is getting a snazzy little cage/armor surround so it will look the part. Here is the start of that.
I also trimmed out the side cover for the side without the oil tank, but was unable to mount it, so no pics. The windscreen got some trim, but I haven't worked out it's design yet. More to do there. So tomorrow is finish the side cover, the oil tank, and maybe the headlight cowl and wind screen mounting. I also have a plan for completing the chain driven shifter linkage, with the parts in house -minus bearings. The only issue is the torn down state of the bike. Sooooo... I gotta put it back together to mock up the shifter...
Still on the board (in no certain order):
Tomorrows welding
Custom dash and clocks (this one is giving me some trouble at the moment)
Upholster seat and back rest
Get motor temporarily back in the frame
Mount rear sets and brakes.
Prep and paint rear wheel (front end has been done for a while, damn ADHD)
Dress up shocks
Final tear down and prep (frame, motor, headlight cowl, etc.)
Paint like there is no tomorrow
Rewire to add updated parts (still undecided if its getting a new loom, or just strip down modified)
On the 'WTF am I thinking' list:
I'm thinking of machining a points cover from billet stock by hand. Don't really know why, other than my stocker is crap and I have some thick slabs of aluminum. Plus it'd be cool. I still have to figure out how to back light the wind screen. I have the concept down but hiding it is gonna be a real bitch. I want to drill the brakes, but they just might be crap so as funds allow I have some e-baying to do. Also have to wait for funds to buy handle bars, cables, wire, grips, paint and prep supplies. I'd gripe about being broke, and how this thing would have been done moths ago if I had the cash, but then it would not have had the time to evolve like it has. C'est la vive.
Oh, and I think the tag "Ground Resistance" from my sig might end up being the beast's final moniker. Any ideas? Questions? Thoughts? Blinding flashes of insight?
