Ground Resistance
Re: CB750-F3 'Filthy Beast'
CresentSon said:
I'm thinking a fighter squadron logo on the front of the tank with my name painted in script. Maybe some sort of little hash marks for the "kills" of the pilot?
I am not sure about this one cresent, I think with all you have going on, this might be the straw that breaks the camels back! This might make it "too busy"! I know it is busy already, but it all melds into the same feel, plenty for the eyes to scan over and take in all the little details you have incorperated into the theme! The above mentioned added on the tank to me might just draw the eye there mainly and kill the eveness of the details you have. To me, something like that make you want to look at it more than the rest of the bike and it's details. I would loose the 13 too, the logo you have is sweet and I think it will do its job alone. If you do other logos, letters, and numbers; your just taking away attention from that logo. Just my opinion brother and I just tell it like I see it, I like honest opinions so thats what I give. You have one really bad ass build idea going and I know its going to kill no matter what you do, I would just hate to see you over do a great scheme.
Cheers bro and keep up the wrenching, show us some pics of the steel when you get some time to work on her!
Im with ^^^^. Too much could turn a really cool design into something that looks thrown together. Also, the numbers dont really run with the theme either. The logo you designed is badass, and will look great, but the numbers imply a race feel, which I think kind of counters the artistic vibe of the dieselpunk... Just my opinion. Really want to see this thing all together though! It will be really interesting to see all the ideas in the flesh.
I humbly agree on the 13. I was shooting for more of a unit number like police or military. Might try a scaled down font and something a little more like a serial #. As far as the squad logo, I was thinking something an inch or two tall on the leading edge of the tank, probably on the opposite side as it should be less busy, but still not written in stone. More of an after thought really. I do thank you for the honest feed back. I want this thing to look cool, not like something a 12 year old slapped together for the sci-fi convention at 3 AM.
Anywho, youze guys wanted to see something in the metal, in the flesh? Ask and you shall receive.
Here is the cover mid carve.
And afta paint.
I hope to wipe/brush black into the cracks so it looks dirty. It should pop once the cracks and scratches are low lighted. I thought about laying the black in and wet sanding, but I want the aluminum spray to show, and with all the corners I'd probably blow through the base coat. I could lay it down thick, but that would cause a loss of detail. We'll see what happens when it cures.
cresent, you may want to try this to get your black in the recesses.
Using a cloth that is not thick and fiberous and is lint free, wrap it around a small bock of wood. Using a paint marker from the model car section of your local hobby store, run the paint into the areas you want the black. Then wipe over the area pretty quickly after painting with the rag covered block damp with a little thinner. This should leave most of the paint in the recess and smear most of the rest off but leave just a little like natural grime that was wiped!
I have used this a few time and it worked great for me, your application is similar and should work for you too! I hope it helps!
As far as the number goes, if you have to have something like that, what about bar code?
Thanks Twisted. I'll try that because the black auto paint seems to lift the base paint on the test pieces Ive done. I like the bar code idea too. I'll do a mock up when I get the chance.
Sucks that the black is lifting the base. May have to switch to another black. When you get to it if the Thinner wants to take the base might try mineral spirits or denatured alochol.
Bar code would be cool.
wow that cover is gonna look cool when you get it done. I would probably try the paint marker too. If it works using twisted's method you could touch it up really easy. I would think it would and I dont see a paint marker reacting with the paint on the cover.
Swapmeet Louie said:
Ummm... How about just getting it dirty
Don't think I have not considered it!
The paint in question is rustoleum engine enamel (500*) so I tossed it in the oven, and I'm gonna give it some cure time before proceeding. At least I have plenty to do while I wait.
Thanks again for the positive reinforcement fellas!
Here is the logo w/barcode. I actually found a site that generates barcodes, so it still says 13. HeHeHe...
I'm digging the barcode too. might have to work it in on my helmet.
thompsonmx100 said:
Did your paint work or no.
I won't know until the AM. I think I will pick up some model paint per Twisted's suggestion. Pretty sure some eperimentation is in order. I also plan on picking up the sheet metal on Thursday, and that should give me two solid days to start fab work on the tail.
I'm working on the paint scheme now and should have a descision shortly. Still going with aluminum and black, but might work in gun metal gray, hammered silver, and possibly very limited quantities of sunrise red or cobalt blue. I figure that will help me work in more visual layers without resorting to strapping on a bunch of crap and dead weight.
cresent, I suggest sticking with "colors" on the grayscale. I think the look of lack of "color" really hits the mark on the diesel punk look, besides you plan on using some LED lights to backlight some areas and that can serve as some contrast. I am not a fan of LED's on cafe bikes but your bike kind of has a catagory of it's own, so I feel OK with your application. Try more tones of the gray and alloy colors. There are a ton of paints out there that are metal look, grey, and hammered in tones that fit your scheme. I think there is more than enough available to create depth on multiple layers in you scheme. Just my $.02 on it!
Hurry up and get done already so I can throw this up for BOTM! :P
Seriously, I love where you're going here and everything is looking top notch. Great job dude.
I just went throught this whole thread and had to run outside to gasp for fresh air. That's a busy brain you got going in that skull CrescentSon. Very nice ideas. I can easily see this turning into a top notch bike once it's done. Kepp up the good work. Great advice from the guys who have been comenting on your mods so far. Aslo good encouragement on their part.
Damn guys, you sure know how to make a girl blush... :-[
I just hope I can get some real progress going. I feel like all this detail and etching is going on forever, and I need the gratification of some larger scale fab work. Payday tomorrow, then the real fun starts. That means today is all about more painstaking little details.
Funny, I have always suffered from the delusion that I was a big picture guy. So much to do so little time.
Twisted, on the 'color' the idea was dry brushing extremely small amounts in obscure areas so it would look like paint transfer or scrapes just for texture. I have a feeling that this thing is gonna look better roughed up a bit. That is a last step kinda thing, and apparently I change my mind like a chick picking out a prom dress so who knows. Lots of time left to ponder it. :)
xulf13 said:
...Aslo good encouragement on their part.
Yup, I would still be scratching my head without my posse think tank. You guys do in fact rock out loud!
