Ground Resistance
Re: Ground Resistance - Rear Brake
Looks good Crescent! I'm assuming that bracket was too big but handy so it went on? Looks like a lot could come off. Either way, good job!
It wasn't handy at all, in fact it was a pain in the ass. I tried using a flat plate, but it did not work out. This might end up being a prototype if I cannot get it trimmed sufficiently.
That is bad ass.
As far as trimming it down, what about this option? Trim the channel to match the angle of the rear support, weld in a piece of flat stock for an added brace and to prevent you foot from catching on a corner. Then some Crescent flair in the space behind.
That is what I needed Jay! Then I can round the top corner (the one with the weld) and tweak the bit sticking out below the lever at a similar angle!
....Brilliant!
haha, love that pic.
This bike is an inspiration, I always get stuck in what other people think when I design/build. Glad to think outside the box and photoshop something other than furniture and fireplaces.
Alright Jay my boy, here is what I came up with. TH matching angles from your photoshop didn't happen, but I think it is still pretty cool. It makes a statement, looks cool, and will really blend in. All in all, I'm happy, thanks for kicking me into gear man.
Re: Ground Resistance - Fab is Fin...
For all intents and purposes fab is done. Well not completely. The slicer number plate, the blinker covers, the rear fender mount, and a spring latch for the elcetrics cover still need to be finished. Those projects don't impede paint and engraving though. Next is paint, then engine, but first pics!
Headlamp in place. Sexy...
Side shot.
Walk around vid. I don't narrate so just use your imagination. In mine its Robin Leach, rich and famous style.
http://s300.photobucket.com/albums/nn34/drl001/CB750F3/?action=view&current=03042011015.mp4
I also tried making a pvc velocity stack. Not too bad for a first try, but a little refining is in order.
The positive mold on the left is the resin compound used to plug bowling balls. A pro shop owner I know pours the excess into plastic dixie cups, and throws it away when it dries. I acquired a few from him a while back. I chucked it up on my wood lathe and turned the bell shape. The pvc was lightly heated with a plumbers torch, and forced onto the mold. When that was done and cool I chucked the pvc onto the lathe to sand and even the edges.
Here is the finished product between the pipe blank and the original rubber stack from the airbox. there is actually a lot more taper than it would seem because I thinned the material around the lip of the bell to make it more streamlined. It has as much, if not more taper than the stock piece.
Ahhhhh. A sigh of relief. Beware though, for it's the little things that can cause the biggest headaches.
Great work so far Crescent. Its good to see a profile shot.
Beware heating PVC, it's highly toxic and will outgas above a certain temperature.
Dieing probably sucks.....dieing of poison gas, almost assuredly sucks.
I feel ya there Rich, but I'm too elated for words right now. The little stuff will get punched out as I grind and prep for paint. I'm just happy to be switching gears a bit.
Thanks for the heads up Swag, I read up on the pvc 'gassing' quite a bit, and think I avoided any toxins. You can almost get the material hot enough using boiling water, but that took too darn long. I think a heat gun may be a sound investment.
At least it won't be much longer till we find out Glenn, paint starts flying Wednesday if weather permits. We'll be surprised together, cuz i don't have much of a plan...
awesome to see a profile shot. Very hard to pick a favorite part but I keep coming back to the faring. Its just sick. Pretty cool on the pvc stack formed on a bowling ball plug turned on a lathe. Who would have ever thunk that? Congrats on the moving into next phase. Can't wait....
The frame mods could be cool, the shocks are probably just getting the paint patina though. I have too much texture to sand around as it is. I've been grinding and wire wheeling all evening, and I don't think I have even made a dent. :)
looks great!! if you take some paint stripper and just hit the shock springs then use water to wash it off... let it sit outside as it drys and it will flash rust almost right away... then clear... boom shocks are done!
Rev:
you can not just clear that frame it is going to need to be cleaned up or it will outgass, smoke, and burn out in a oven, it is dangerous for the workers of the powder coating shop, and the finish will look like shit not to mention that it will not hold up at all, just will chip and flake
That corseted foot peg looks awesome. Well done. it looked like it could have been a bit of a bitch to match angles but this just adds to the the layers of texture.
Ped slicer 2.0 rough and ready for paint.
Still deciding what to paint on the solid side, but I like the asymmetry. Back to work.
Threw the slicer on the frame for shits and giggles.
First pair of switches in place and wired.
