Ground Resistance
Re: Ground Resistance: Wiring Diagram Updated
Methinks we need some more pics in this thread.
Gimme a bit Paul, least I can do in return for those hot shots of the BastardWing.
Sure did brother. That side cover is smooth as glass, and the whole bike looks like something from a Knight Rider spin off.
As requested, here is the proposed layout for the electrical components on the battery box. Front and center is the starter solenoid, bottom right is a bridge rectifier, bottom left is the fuse block. That mass of twisted wire to the far left is the heavily modified Ford regulator. The details of the reg and rec are in the $50 mod thread somewhere.
Here is the regulator up close. It was liberated from it's huge sheet metal factory enclosure and insulated, wrapped in scrap wire, painted, and given a heavy patina.
Here it all is crammed in the frame. few little problems. The solenoid just touches the side cover when closed. I also want a little more clearance on the bottom right between the battery box and the rear mud guard decorations. Those wire things will get beat out of the way with a hammer. ;D
Tight fit with the cover closed. Need to relocate the starter solenoid. :-\
And the new addition to the dash. the more I look at it, the more I'm considering just using one switch for the main, with a hidden switch in line somewhere. The other two could be winkers and high low maybe.
I love the switch idea, but I was wondering, how about getting a few second hand ones from somewhere (perhaps some antique ebay switches?) and making them as mismatched as possible to go with that real steampunk feel.
This one looks interesting though I think I like the box it comes in more.
http://www.ebay.com.au/itm/VINTAGE-ANTIQUE-HEADLITE-SWITCH-PT3-/110508933996?pt=Vintage_Car_Truck_Parts_Accessories&hash=item19bad8836c
I had thought about that, and mismatched clocks have been suggested before. Both options might be in the future, but for now I need to keep making headway. I can always go back and update (maybe retrofit is a better word choice). Right now I'm hurting to hear it run. It has just been far too long.
After the bike is running I have cobbled together all the supplies to build my casting foundry/steel forge. I might have to cast some embellishments once I'm up and running. By summer I should be able to sandcast brass, copper, and aluminum. Then I can engrave the castings! I'm considering documenting the processes involved with video. If not I'll definitely post a how to thread.
I have seen similar items, new, at the auto parts store. The momentary switch for the starter I want looks really similar too.
Fair call, get her going then retrofit. I like it.
Re: Ground Resistance: First Round Wiring Pics
As usual, there's not much input I can give other than saying "bad ass."
Curious if the frame will get some crazy patina'd paint? Or stay black? I may have missed it, but with 100+ pages, hope you will excuse me.
It will get some love when I patina the motor. Hopefully next week. The wiring is taking longer than I wanted mostly because I keep finding "better" things to do. There are also a few issues with stuff that had to be fabbed, like the reg cage, and now the mount for the solenoid. I almost have it done, but I'm about to call it a night.
And I'll get that pic first thing in the morning Brother. Just have to throw the tank and seat back on.
Oh man.. see.. I've seen it in person.. and let me tell you.. WHHEEEEEWWWWWWWWWWW you people aren't going to know what hit you come Barber..
Dano you are going to Barber, yeah?
I'll do everything I can to make it. If I can't make it happen, you have the right to kick my ass.
There's talk of renting an RV.. juuuuuust sayin...
