PancakeShake
Ok.
So.
Re wired my bike cause it was kind of a mess, 99.99999% sure everything is in the correct spot because my bke starts, runs and drives fine.
However, I have popped like 6 fuses because my ground wire off the battery is heating up and touching off on other wires, cause them to melt and fuse to the ground, therefore popping the fuse.
I moved the ground wire away from everything else so it cant touch off and do this, but I would rather solve the problem and figure out why it is doing this.
I read somewhere about the ignition key might have something to do with this issue in bikes.
I rewiried the ignition key to a dual switch ignition (keyless). Could these switches be the issue possibly?
Thanks.
So.
Thanks.
